Datasheet 6N137, HCNW137, HCNW2601, HCNW2611, HCPL-0600, HCPL-0601, HCPL-0611, HCPL-0630, HCPL-0631, HCPL-0661, HCPL-2601, HCPL-2611, HCPL-2630, HCPL-2631, HCPL-4661 (Broadcom) - 2
ПроизводительBroadcom
ОписаниеHigh CMR, High Speed TTL Compatible Optocouplers 6N137, HCPL-26xx/06xx/4661, HCNW137/26x1
Страниц / Страница29 / 2 — Selection Guide. Small-Outline SO-8. Widebody. Minimum CMR. 8-Pin DIP …
Selection Guide. Small-Outline SO-8. Widebody. Minimum CMR. 8-Pin DIP (300 Mil). Hermetic. Input On-. (400 Mil). Output. Current. Enable
Selection Guide Small-Outline SO-8 Widebody Minimum CMR 8-Pin DIP (300 Mil) Hermetic Input On- (400 Mil) Output Current Enable
46 предложений от 22 поставщиков
Оптопара/ оптоизолятор, Logic IC Output Optocoupler, 2Element, 3750V Isolation, 10Mbps, ROHS COMPLIANT, SOIC-8
HCPL-0630-000E
Broadcom
360 ₽
DIP8.RU
Россия и страны ТС
HCPL-0630-000E
Broadcom
от 523 ₽
Контест
HCPL-0630-000E
552 ₽
ТаймЧипс
HCPL-0630-000E
Avago Technologies
link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 6N137, HCNW137, HCNW2601, HCNW2611, HCPL-0600, HCPL-0601, HCPL-0611, Selection Guide HCPL-0630, HCPL-0631, HCPL-0661, HCPL-2601, HCPL-2611, HCPL-2630, HCPL-2631, HCPL-4661 Data Sheet The 6N137, HCPL-26xx, HCPL-06xx, HCPL-4661, HCNW137, and HCNW26x1 are suitable for high speed logic interfacing, input/output buffering, as line receivers in environments that conventional line receivers cannot tolerate and are recommended for use in extremely high ground or induced noise environments.
Selection Guide Small-Outline SO-8 Widebody Minimum CMR 8-Pin DIP (300 Mil) Hermetic Input On- (400 Mil) Output Current Enable Single Single Single Single and dV/dt (mA) Dual Channel Dual Channel V Channel Channel Channel Dual Channel (V/μs) CM (V) Package Package Package Package Package Packages
1000 10 5 YES 6N137 5,000 1,000 5 YES HCPL-0600 HCNW137 NO HCPL-2630 HCPL-0630 10,000 1,000 YES HCPL-2601 HCPL-0601 HCNW2601 NO HCPL-2631 HCPL-0631 15,000 1,000 YES HCPL-2611 HCPL-0611 HCNW2611 NO HCPL-4661 HCPL-0661 1,000 50 YES HCPL-2602a 3, 500 300 YES HCPL-2612a 1,000 50 3 YES HCPL-261Aa HCPL-061Aa NO HCPL-263Aa HCPL-063Aa 1,000b 1,000 YES HCPL-261Na HCPL-061Na NO HCPL-263Na HCPL-063Na 1,000 50 12.5 c HCPL-193xa HCPL-56xxa HCPL-66xxa a. Technical data are on separate Avago publications. b. 15 kV/μs with VCM = 1 kV can be achieved using Avago application circuit.3 c. Enable is available for single channel products only, except for HCPL-193x devices.
Ordering Information
HCPL-xxxx is UL Recognized with 3750 Vrms for 1 minute per UL1577. HCNWxxxx is UL Recognized with 5000 Vrms for 1 minute per UL1577. Avago Technologies - 2 - Document Outline High CMR, High Speed TTL Compatible Optocouplers Description Functional Diagram Features Applications Selection Guide Ordering Information Schematic Package Outline Drawings 8-pin DIP Package (6N137, HCPL-2601/11/30/31, HCPL-4661) 8-pin DIP Package with Gull Wing Surface Mount Option 300 (6N137, HCPL-2601/11/30/31, HCPL-4661) Small-Outline SO-8 Package (HCPL-0600/01/11/30/31/61) 8-Pin Widebody DIP Package (HCNW137, HCNW2601/11) 8-Pin Widebody DIP Package with Gull Wing Surface Mount Option 300 (HCNW137, HCNW2601/11) Reflow Soldering Profile Regulatory Information Insulation and Safety Related Specifications IEC/EN/DIN EN 60747-5-5 Insulation Characteristics (HCPL-06xx Option 060 Only) IEC/EN/DIN EN 60747-5-5 Insulation Characteristics (HCPL-26xx; 46xx; 6N13x Option 060 Only) IEC/EN/DIN EN 60747-5-5 Insulation Characteristics (HCNW137/2601/2611 Only) Absolute Maximum Ratings (No Derating Required up to 85 °C) Recommended Operating Conditions Electrical Specifications Switching Specifications (AC) Package Characteristics Propagation Delay, Pulse-Width Distortion and Propagation Delay Skew
