Datasheet KSZ8775CLX (Microchip) - 10
ПроизводительMicrochip
ОписаниеIntegrated 5–Port 10/100 Managed Ethernet Switch with Port 4 RMII and Port 5 RGMII/MII/ RMII Interfaces
Страниц / Страница132 / 10 — KSZ8775CLX. TABLE 2-1:. Num Pins 54 55 56 57 58 59 SIGNALS (CONTINUED). …
Формат / Размер файлаPDF / 2.3 Мб
KSZ8775CLX. TABLE 2-1:. Num Pins 54 55 56 57 58 59 SIGNALS (CONTINUED). Pin Name RXD5_3 RXDV5/CRSDV5
KSZ8775CLX TABLE 2-1: Num Pins 54 55 56 57 58 59 SIGNALS (CONTINUED) Pin Name RXD5_3 RXDV5/CRSDV5
26 предложений от 16 поставщиков
Интегральные микросхемы Интерфейс - Контроллеры
KSZ8775CLXIC
493 ₽
KSZ8775CLXIC
626 ₽
Эиком
KSZ8775CLXIC
от 1 178 ₽
Hi-Tech Circuit Group
KSZ8775CLXIC
KSZ8775CLX
TABLE 2-1:
/RXD5_CTL RXER5 CRS5 COL5 REFCLKO Type IPD/O IPD/O IPD/O IPD/O IPD/O PME_N I/O 61 GNDD GND 62 TXEN4 IPD Pin Description 5 RGMII/MII:
Port 5 switch receive bit [3]
RMII:
No connection. 5 MII:
RXDV5 is for Port 5 switch MII receiving data
valid.
RMII:
CRSDV5 is for Port 5 RMII carrier sense/receive
data valid output.
RGMII:
RXD5_CTL is for Port 5 RGMII receiving data
control. 5 MII:
Port 5 switch receive error.
RGMII/RMII:
Port 5 switch MII modes carrier sense.
RGMII/RMII:
Port 5 Switch MII collision detect.
RGMII/RMII:
No connection.
25 MHz clock output (Option)
Controlled by the strap pin LED2_0.
Default is enabled; it is better to disable it if not
using it. IPU/O 60 DS00002129C-page 10 Port Power Management Event
This output signal indicates that a wake-on-LAN
event has been detected as a result of a wake-up
frame detection. The KSZ8775CLX is requesting
the system to wake up from low power mode. Its
assertion polarity is programmable with the
default polarity set to active low.
Digital ground
4 RMII:
Port 4 switch SW4-RMII transmit enable.  2015 Microchip Technology Inc.
