Линейка продуктов KEEN SIDE
Datasheet LM340, LM340A, LM7805, LM7812, LM7815 (Texas Instruments) - 6
ОписаниеWide VIN 1.5-A Fixed Voltage Regulators
Страниц / Страница34 / 6 — LM340,. LM340A. , LM7805,. LM7812. , LM7815. www.ti.com. 6.6 LM340 / …
ВерсияL
Формат / Размер файлаPDF / 3.8 Мб
LM340,. LM340A. , LM7805,. LM7812. , LM7815. www.ti.com. 6.6 LM340 / LM7805 Electrical Characteristics, VO = 5 V, VI = 10 V
LM340, LM340A , LM7805, LM7812 , LM7815 www.ti.com 6.6 LM340 / LM7805 Electrical Characteristics, VO = 5 V, VI = 10 V
SNOSBT0L – FEBRUARY 2000 – REVISED SEPTEMBER 2016
0°C ≤ TJ ≤ 125°C unless otherwise specified(1)
PARAMETER TEST CONDITIONS MIN TYP MAX UNIT
TJ = 25°C, 5 mA ≤ IO ≤ 1 A 4.8 5 5.2 V VO Output voltage PD ≤ 15 W, 5 mA ≤ IO ≤ 1 A 4.75 5.25 V 7.5 V ≤ VIN ≤ 20 V TJ = 25°C 3 50 mV 7V ≤ VIN ≤ 25V IO = 500 mA Over temperature 50 mV 8V ≤ VIN ≤ 20V ΔVO Line regulation TJ = 25°C 50 mV 7.5V ≤ VIN ≤ 20V IO ≤ 1 A Over temperature 25 mV 8V ≤ VIN ≤ 12V 5 mA ≤ IO ≤ 1.5 A 10 50 mV TJ = 25°C ΔVO Load regulation 250 mA ≤ IO ≤ 750 mA 25 mV Over temperature, 5 mA ≤ IO ≤ 1 A 50 mV TJ = 25°C 8 mA IQ Quiescent current IO ≤ 1 A Over temperature 8.5 mA 0°C ≤ TJ ≤ 125°C, 5 mA ≤ IO ≤ 1 A 0.5 mA T ΔI J = 25°C, IO ≤ 1 A 1 mA Q Quiescent current change 7 V ≤ VIN ≤ 20 V Over temperature, IO ≤ 500 1 mA mA VN Output noise voltage TA = 25°C, 10 Hz ≤ f ≤ 100 kHz 40 μV T f = 120 Hz J = 25°C, IO ≤ 1 A 62 80 dB Ripple rejection Over temperature, I 62 8 V ≤ V O ≤ 500 IN ≤ 18 V mA dB Dropout voltage TJ = 25°C, IO = 1 A 2 V Output resistance f = 1 kHz 8 mΩ RO Short-circuit current TJ = 25°C 2.1 A Peak output current TJ = 25°C 2.4 A Average TC of VOUT Over temperature, IO = 5 mA −0.6 mV/°C VIN Input voltage required to TJ = 25°C, IO ≤ 1 A 7.5 V maintain line regulation (1) All characteristics are measured with a 0.22-μF capacitor from input to ground and a 0.1-μF capacitor from output to ground. All characteristics except noise voltage and ripple rejection ratio are measured using pulse techniques (tw ≤ 10 ms, duty cycle ≤ 5%). Output voltage changes due to changes in internal temperature must be taken into account separately. 6 Submit Documentation Feedback Copyright © 2000–2016, Texas Instruments Incorporated Product Folder Links: LM340 LM340A LM7805 LM7812 LM7815 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 LM340A Electrical Characteristics, VO = 5 V, VI = 10 V 6.6 LM340 / LM7805 Electrical Characteristics, VO = 5 V, VI = 10 V 6.7 LM340 / LM7812 Electrical Characteristics, VO = 12 V, VI = 19 V 6.8 LM340 / LM7815 Electrical Characteristics, VO = 15 V, VI = 23 V 6.9 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Output Current 7.3.2 Current Limiting Feature 7.3.3 Thermal Shutdown 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.1.1 Shorting the Regulator Input 8.1.2 Raising the Output Voltage Above the Input Voltage 8.1.3 Regulator Floating Ground 8.1.4 Transient Voltages 8.2 Typical Applications 8.2.1 Fixed Output Voltage Regulator 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curve 8.3 System Examples 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 10.3 Heat Sinking DDPAK/TO-263 and SOT-223 Package Parts 11 Device and Documentation Support 11.1 Documentation Support 11.1.1 Related Documentation 11.2 Related Links 11.3 Receiving Notification of Documentation Updates 11.4 Community Resources 11.5 Trademarks 11.6 Electrostatic Discharge Caution 11.7 Glossary 12 Mechanical, Packaging, and Orderable Information Page 1
