Datasheet RH1016M (Analog Devices) - 6
ОписаниеUltraFast Precision 10ns Comparator
Страниц / Страница6 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Positive Power Supply. Input Offset …
Формат / Размер файлаPDF / 119 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Positive Power Supply. Input Offset Voltage. Small-Signal Voltage Gain. Rejection Ratio
TYPICAL PERFORMANCE CHARACTERISTICS Positive Power Supply Input Offset Voltage Small-Signal Voltage Gain Rejection Ratio
Three Terminal Voltage Reference, 1 Output, 10V, Trim/Adjustable, MBCY8
ЗУМ-СМД
RH1016MW
RH1016MW
RH1016M
3.0 3000 90 V V S = ±5V V– = –5V 2.5 S = ±5V 1V ≤ V R OUT ≤ 2V S ≤ 100Ω 85 4.6V ≤ V+ ≤ 5.4V 2.0 2500 80 1.5 1.0 75 2000 0.5 70 0 –0.5 1500 65 –1.0 60 –1.5 INPUT OFFSET VOLTAGE (mV) 1000 –2.0 SMALL-SIGNAL VOLTAGE GAIN (V/V) 55 –2.5 –3.0 500 POSITIVE POWER SUPPLY REJECTION RATIO (dB) 50 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1016 G09 RH1016 G10 RH1016 G11
Negative Power Supply Rejection Ratio LATCH Pin Current
120 0 V+ = 5V VS = ±5V 115 –7V ≤ V– ≤ –2V –50 VLATCH = 0V –100 110 –150 105 –200 100 –250 95 –300 –350 90 LATCH PIN CURRENT (μA) –400 85 –450 80 –500 NEGATIVE POWER SUPPLY REJECTION RATIO (dB) 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1016 G12 RH1016 G13 I.D. No. 66-10-1016 rh1016fa 6 Linear Technology Corporation LT 0508 REV A • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com © LINEAR TECHNOLOGY CORPORATION 2007
