Datasheet LTC1863L, LTC1867L (Analog Devices) - 4
ОписаниеMicropower, 3V, 16-Bit, 8-Channel 175ksps ADCs
Страниц / Страница16 / 4 — DIGITAL INPUTS AND DIGITAL OUTPUTS The. denotes the specifications which …
Формат / Размер файлаPDF / 256 Кб
DIGITAL INPUTS AND DIGITAL OUTPUTS The. denotes the specifications which apply over the
DIGITAL INPUTS AND DIGITAL OUTPUTS The denotes the specifications which apply over the
36 предложений от 22 поставщиков
Микросхема Преобразователь AD, Analog to Digital Converter, Octal, 12Bit, 175KSPS, Single, 2.7V, 3.6V, SSOP
LTC1863LIGN#TRPBF
447 ₽
LTC1863LIGN#TRPBF
509 ₽
Microfind
LTC1863LIGN#TRPBF
978 ₽
LifeElectronics
LTC1863LIGN#TRPBF
LTC1863L/LTC1867L
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) LTC1863L/LTC1867L/LTC1867LA SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IIN Digital Input Current VIN = 0V to VDD l ±10 µA CIN Digital Input Capacitance 2 pF VOH High Level Output Voltage (SDO) VDD = 2.7V, IO = –10µA 2.68 V VDD = 2.7V, IO = –200µA l 23 2.65 V VOL Low Level Output Voltage (SDO) VDD = 2.7V, IO = 160µA 0.05 V VDD = 2.7V, IO = 1.6µA l 0.15 0.4 V ISOURCE Output Source Current SDO = 0V –9.7 mA ISINK Output Sink Current SDO = VDD 6 mA Hi-Z Output Leakage CS/CONV = High, SDO = 0V or VDD l ±10 µA Hi-Z Output Capacitance CS/CONV = High (Note 10) l 15 pF Data Format Unipolar Straight Binary Bipolar Two’s Complement
POWER REQUIREMENTS The
l
VDD Supply Voltage (Note 9) 2.7 3.6 V IDD Supply Current fSAMPLE = 175ksps, Internal REF l 0.75 1 mA NAP Mode 170 µA SLEEP Mode l 0.2 3 µA PDISS Power Dissipation fSAMPLE = 175ksps l 2 2.7 mW
TIMING CHARACTERISTICS The
l
fSAMPLE Maximum Sampling Frequency l 175 kHz tCONV Conversion Time l 3.2 3.7 µs tACQ Acquisition Time l 2.01 1.68 µs fSCK SCK Frequency 20 MHz t1 CS/CONV High Time Short CS/CONV Pulse Mode l 40 100 ns t2 SDO Valid After SCK↓ CL = 25pF (Note 11) l 22 47 ns t3 SDO Valid Hold Time After SCK↓ CL = 25pF l 5 17 ns t4 SDO Valid After CS/CONV↓ CL = 25pF l 20 40 ns t5 SDI Setup Time Before SCK↑ l 15 –6 ns t6 SDI Hold Time After SCK↑ l 15 6 ns t7 SLEEP Mode Wake-Up Time CREFCOMP = 10µF, CVREF = 2.2µF 80 ms t8 Bus Relinquish Time After CS/CONV↑ CL = 25pF l 30 50 ns
Note 1:
Note 3:
When these pin voltages are taken below GND or above VDD, they may cause permanent damage to the device. Exposure to any Absolute will be clamped by internal diodes. This product can handle input currents Maximum Rating condition for extended periods may affect device up to 100mA without latchup. reliability and lifetime.
Note 2:
All voltage values are with respect to GND (unless otherwise noted). 1863l7lfe 4 For more information www.linear.com/LTC1863L Document Outline Description Absolute Maximum Ratings Pin Configuration Typical Performance Characteristics Pin Functions Package Description Related Parts
