Datasheet LTC2512-24 (Analog Devices) - 3
Описание24-Bit Over-Sampling ADC with Configurable Flat Passband Digital Filter
Страниц / Страница38 / 3 — The. denotes
Формат / Размер файлаPDF / 709 Кб
The. denotes
The denotes
19 предложений от 12 поставщиков
IC ADC 24BIT SAR 24DFN. 24 Bit Analog to Digital Converter 1 Input 1 SAR 24-DFN (7x4). Data Acquisition - Analog...
LTC2512IDKD-24#TRPBF
493 ₽
521 ₽
1 238 ₽
LTC2512IDKD-24#PBF
2 135 ₽
LTC2512-24 CONVERTER CHARACTERISTICS FOR FILTERED OUTPUT (SDOA)
The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution l 24 Bits No Missing Codes l 24 Bits DF Down-sampling Factor l 4 32 Transition Noise DF = 4 (Note 6) 21 LSBRMS DF = 8 (Note 6) 14.9 LSBRMS DF = 16 (Note 6) 10.5 LSBRMS DF = 32 (Note 6) 7.5 LSBRMS INL Integral Linearity Error (Note 7) l –3.5 ±1 3.5 ppm ZSE Zero-Scale Error (Note 9) l –14 0 14 ppm Zero-Scale Error Drift ±7 ppb/°C FSE Full-Scale Error (Note 9) l –100 ±10 100 ppm Full-Scale Error Drift ±0.05 ppm/°C DYNAMIC ACCURACY FOR FILTERED OUTPUT (SDOA)
The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C and AIN = –1dBFS. (Notes 4, 10) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
DR Dynamic Range fIN = 2kHz, VREF = 5V, DF = 4 108 dB fIN = 2kHz, VREF = 5V, DF = 8 111 dB fIN = 2kHz, VREF = 5V, DF = 16 114 dB fIN = 2kHz, VREF = 5V, DF = 32 117 dB SINAD Signal-to-(Noise + Distortion) Ratio fIN = 2kHz, VREF = 5V, DF = 4 l 103 107 dB SNR Signal-to-Noise Ratio fIN = 2kHz, VREF = 5V, DF = 4 l 103 107 dB THD Total Harmonic Distortion fIN = 2kHz, VREF = 5V, DF = 4 l –120 –110 dB fIN = 2kHz, VREF = 2.5V, DF = 4 –120 dB SFDR Spurious Free Dynamic Range fIN = 2kHz, VREF = 5V, DF = 4 l 110 120 dB fIN = 2kHz, VREF = 2.5V, DF = 4 120 dB Aperture Delay 500 ps Aperture Jitter 4 psRMS Transient Response Full-Scale Step 152 ns 251224fa For more information www.linear.com/LTC2512-24 3
