Datasheet HMC631LP3, 631LP3E (Analog Devices) - 7
ОписаниеGaAs HBT Vector Modulator 1.8 -2.7 GHz
Страниц / Страница8 / 7 — HMC631LP3 / 631LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.7 MHz. Evaluation …
Формат / Размер файлаPDF / 848 Кб
HMC631LP3 / 631LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.7 MHz. Evaluation PCB. List of Materials for Evaluation PCB 117201 [1]
HMC631LP3 / 631LP3E GaAs HBT VECTOR MODULATOR 1.8 - 2.7 MHz Evaluation PCB List of Materials for Evaluation PCB 117201 [1]
12 предложений от 9 поставщиков
RF MODULATOR 1.8GHZ-2.7GHZ 16QFN. RF Modulator IC 1.8GHz ~ 2.7GHz 16-VFQFN Exposed Pad. RF Modulators
HMC631LP3ETR
1 622 ₽
HMC631LP3ETR
2 146 ₽
HMC631LP3ETR
от 4 601 ₽
727GS
HMC631LP3ETR
HMC631LP3 / 631LP3E
v00.1007
10 T - SM S R O T A L U MOD
The circuit board used in the fi nal application should Item Description use RF circuit design techniques. Signal lines J1 - J4 PCB Mount SMA Connector should have 50 ohm impedance while the package J5 2 mm DC Header ground leads and exposed paddle should be con- C1 4.7 μF Capacitor, Tantalum nected directly to the ground plane similar to that C2 - C5 100 pF Capacitor, 0402 Pkg. shown. A sufficient number of via holes should be Balun, 0805 Pkg. T1 ANAREN BD1722J50100A used to connect the top and bottom ground planes. L1 330 nH Inductor, 0805 Pkg. The evaluation board should be mounted to an U1 HMC631LP3(E) Vector Modulator appropriate heat sink. The evaluation circuit board PCB [2] 117196 Evaluation PCB shown is available from Hittite upon request. [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350, Er = 3.48 Information furnishe F d o b r pr y Analic o e g , D d evi e ce li s v i e s brey li , a eve n d t d to p o be acc luac rat e o e an r d d rele ia rs ble , p . Hole we a ves r, e n c o ont Fo ac r p t H rice i, tt dit ele M iveryic , r a owa nd to ve C plac o e r o p rdo e r r at s: i Ao n n al:og Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other
10 - 64
20 Alpha Road, Chelmsford, MA 01824 Phone One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No : 978-250-3343 Fax: 978-250-3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.hi A tt p i pte lic.c atiom n Support: Phone: 1-800-ANALOG-D
