Datasheet HMC642ALC5 (Analog Devices) - 5
ОписаниеGaAs MMIC 6-Bit Digital Phase Shifter, 9 - 12.5 GHz
Страниц / Страница6 / 5 — HMC642ALC5. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 9 - 12.5 GHz. Outline …
Формат / Размер файлаPDF / 467 Кб
HMC642ALC5. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 9 - 12.5 GHz. Outline Drawing. Package Information. Pin Descriptions
HMC642ALC5 GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER, 9 - 12.5 GHz Outline Drawing Package Information Pin Descriptions
22 предложений от 12 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ микросхемы и модули
ЧипСити
HMC642ALC5TR
3 379 ₽
HMC642ALC5TR
3 379 ₽
HMC642ALC5TR
от 35 680 ₽
HMC642ALC5TR
35 817 ₽
HMC642ALC5
v00.0415
T M L - S ITA IG S - D R NOTES: E 1. PACKAGE BODY MATERIAL: ALUMINA T 2. LEAD AND GROUND PADDLE PLATING: 30-80 MICROINCHES GOLD OVER 50 MICROINCHES MINIMUM NICKEL. IF 3. DIMENSIONS ARE IN INCHES [MILLIMETERS]. H 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm DATUM -C- 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. E S 7. CLASSIFIED AS MOISTURE SENSITIVITY LEVEL (MSL) 1.
Package Information
S Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] A H HMC642ALC5 Alumina White Gold over Nickel MSL3 [1] H642A XXXX P [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX
Pin Descriptions
Pin Number Function Description Interface Schematic 1 - 4, 8,17 No connection required. These pins may be connected to N/C 21 - 32 RF/DC ground without affecting performance. These pins and exposed ground paddle 5, 7, 18, 20 GND must be connected to RF/DC ground. 6 RFIN This port is DC coupled and matched to 50 Ohms. 9 - 11, BIT6, BIT5, BIT4, Control Input. See truth table 13 - 15 BIT3, BIT2, BIT1 and control voltage tables. 12 Vss Voltage supply. 16 Vdd Voltage supply. 19 RFOUT This port is DC coupled and matched to 50 Ohms. Informat F io o n r p furn risihcee d , d by e An lialvoe g rDy a evic n e d t s is o p belie lva e c d t e o o b rd e a e cc rursa: A te a n n a d lo reli g D able. e H v o ic weveers, I no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other nc., 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 o plic r a atiopp n S su@ p h po irtttit : Pe. hocno e m : 1-800-ANALOG-D
