Линейка продуктов KEEN SIDE
Datasheet HMC361 (Analog Devices) - 4
ОписаниеGaAs HBT MMIC DIVIDE-BY-2, DC - 11 GHz
Страниц / Страница6 / 4 — HMC361. GaAs HBT MMIC. DIVIDE-BY-2, DC - 11 GHz. Pad Description. 1 - 5
Формат / Размер файлаPDF / 297 Кб
HMC361 GaAs HBT MMIC DIVIDE-BY-2, DC - 11 GHz Pad Description 1 - 5
35 предложений от 21 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ микросхемы и модули
HMC361S8GE
806 ₽
Зенер
Россия и страны ТС
HMC361S8GETR
от 915 ₽
HMC361S8GE
от 2 267 ₽
МосЧип
HMC361_09
Hittite
HMC361
v07.0109
1
Pad Description
Pad Number Function Description Interface Schematic IP H RF Input 180° out of phase with pad 3 for differential operation. 1 IN AC ground for single ended operation. S - C R E 2 IN RF Input must be DC blocked. ID IV 3, 4, 5 Vcc Supply Voltage 5V ±0.25V can be applied to pad 3, 4, or 5. Y D NC E U 6 OUT Divided Output Q E R F 7 OUT Divided output 180° out of phase with OUT. In the low power mode, the power select pin is left fl oating. 8 PWR SEL By grounding this pin, the output power is increased by approximately 10 dB. The power down pin is grounded for normal operation. 9 PWR DWN Applying 5 volts to this pin will power down this device. The disable pin is grounded for normal operation. 10 DISABLE Applying 5 volts to this pin will disable the input buffer amplifi er. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
1 - 5
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
