Datasheet LT8309 (Analog Devices) - 6
ОписаниеSecondary-Side Synchronous Rectifier Driver
Страниц / Страница14 / 6 — pin FuncTions GATE (Pin 1):. VCC (Pin 4):. GND (Pin 2):. DRAIN (Pin 5):. …
Формат / Размер файлаPDF / 232 Кб
pin FuncTions GATE (Pin 1):. VCC (Pin 4):. GND (Pin 2):. DRAIN (Pin 5):. INTV. CC (Pin 3):. block DiagraM
pin FuncTions GATE (Pin 1): VCC (Pin 4): GND (Pin 2): DRAIN (Pin 5): INTV CC (Pin 3): block DiagraM
28 предложений от 16 поставщиков
Микросхема Интегрированный чип особого применения, LINEAR TECHNOLOGY LT8309HS5#TRMPBF Special Function IC, Secondary Side Synchronous Rectifier Driver, 4.5V to 40V, TSOT-23-5
LT8309HS5#TRPBF
105 ₽
Рутоника
LT8309HS5#TRPBF
227 ₽
Элитан
LT8309HS5
669 ₽
727GS
LT8309HS5#TRMPBF
LT8309
N-Channel MOSFET Gate Driver Output.
VCC (Pin 4):
Input Voltage. This pin supplies current to the Switches between INTVCC and GND. Driven to GND during internal start-up circuitry and to the INTVCC LDO. This pin undervoltage lockout of INTVCC. must be locally bypassed with a capacitor.
GND (Pin 2):
Ground.
DRAIN (Pin 5):
Current Sense Pin. This pin senses
INTV
the voltage across the drain-to-source of the external
CC (Pin 3):
Regulated Supply for Internal Loads, and GATE Driver. Supplied from V N-channel MOSFET. A series resistor is needed to set the CC and regulates to 7V (typical). INTV offset voltage and needs to be at least 800Ω. The offset CC must be bypassed with a 4.7µF capacitor placed close to the pin. is equal to:  R 20mV • 1−    2000
block DiagraM
4 VCC 1.25V + 10µA 10µA – INTVCC 3 VBIAS DRAIN 5 + – VBIAS INTVCC LOGIC GATE 1 GND 2 8309 BD 8309fa 6 For more information www.linear.com/LT8309
