Datasheet LTC1871 (Analog Devices) - 3
ОписаниеWide Input Range, No RSENSE Current Mode Boost, Flyback and SEPIC Controller
Страниц / Страница36 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 534 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
28 предложений от 13 поставщиков
LTC1871HMS#TRPBF
194 ₽
LTC1871HMS#TRPBF
261 ₽
LTC1871HMS#TRPBF
331 ₽
LTC1871HMS#TRPBF
LTC1871
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = VINTVCC = 5V, VRUN = 1.5V, RFREQ = 80k, VMODE/SYNC = 0V, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loop
VIN(MIN) Minimum Input Voltage 2.5 V I-Grade or H-Grade (Note 2) ● 2.5 V IQ Input Voltage Supply Current (Note 4) Continuous Mode VMODE/SYNC = 5V, VFB = 1.4V, VITH = 0.75V 550 1000 μA VMODE/SYNC = 5V, VFB = 1.4V, VITH = 0.75V, ● 550 1000 μA I-Grade or H-Grade (Note 2) Burst Mode Operation, No Load VMODE/SYNC = 0V, VITH = 0.2V (Note 5) 250 500 μA VMODE/SYNC = 0V, VITH = 0.2V (Note 5), ● 250 500 μA I-Grade or H-Grade (Note 2) Shutdown Mode VRUN = 0V 10 20 μA VRUN = 0V, I-Grade or H-Grade (Note 2) ● 10 20 μA V + RUN Rising RUN Input Threshold Voltage 1.348 V V – RUN Falling RUN Input Threshold Voltage 1.223 1.248 1.273 V ● 1.198 1.298 V H-Grade (Note 2) ● 1.179 1.315 V VRUN(HYST) RUN Pin Input Threshold Hysteresis 50 100 150 mV I-Grade (Note 2) ● 35 100 175 mV H-Grade (Note 2) ● 35 300 mV IRUN RUN Input Current 1 60 nA VFB Feedback Voltage VITH = 0.2V (Note 5) 1.218 1.230 1.242 V ● 1.212 1.248 V VITH = 0.2V (Note 5), I-Grade or H-Grade (Note 2) ● 1.205 1.255 V IFB FB Pin Input Current VITH = 0.2V (Note 5) 18 60 nA ΔVFB Line Regulation 2.5V ≤ VIN ≤ 30V 0.002 0.02 %/V ΔVIN 2.5V ≤ VIN ≤ 30V, I-Grade or H-Grade (Note 2) ● 0.002 0.02 %/V ΔVFB Load Regulation VMODE/SYNC = 0V, VITH = 0.5V to 0.9V (Note 5) ● – 1 –0.1 % ΔVITH VMODE/SYNC = 0V, VITH = 0.5V to 0.9V (Note 5) ● – 1 –0.1 % I-Grade or H-Grade (Note 2) ΔVFB(OV) ΔFB Pin, Overvoltage Lockout VFB(OV) – VFB(NOM) in Percent 2.5 6 10 % gm Error Amplifi er Transconductance ITH Pin Load = ±5μA (Note 5) 650 μmho VITH(BURST) Burst Mode Operation ITH Pin Voltage Falling ITH Voltage (Note 5) 0.3 V VSENSE(MAX) Maximum Current Sense Input Threshold Duty Cycle < 20% 120 150 180 mV Duty Cycle < 20%, I-Grade or H-Grade (Note 2) ● 100 200 mV ISENSE(ON) SENSE Pin Current (GATE High) VSENSE = 0V 35 50 μA ISENSE(OFF) SENSE Pin Current (GATE Low) VSENSE = 30V 0.1 5 μA
Oscillator
fOSC Oscillator Frequency RFREQ = 80k 250 300 350 kHz RFREQ = 80k, I-Grade (Note 2) ● 250 300 350 kHz RFREQ = 80k, H-Grade (Note 2) ● 240 300 360 kHz Oscillator Frequency Range 50 1000 kHz I-Grade or H-Grade (Note 2) ● 50 1000 kHz 1871fe 3
