Datasheet AT90S1200 (Atmel) - 2
ПроизводительAtmel
Описание8-bit AVR Microcontroller with 1K Byte of In-System Programmable Flash
Страниц / Страница71 / 2 — Description. Block Diagram. Figure 1. AT90S1200
Description Block Diagram Figure 1 AT90S1200
IC MCU 8BIT 1KB FLASH 20SOIC. AVR AVR® 90S Microcontroller IC 8-Bit 12MHz 1KB (512 x 16) FLASH 20-SOIC. Embedded -...
AT90S1200A-12SC
Hi-Tech Circuit Group
AT90S1200A-12SC
AT90S1200A-12SC
TradeElectronics
AT90S1200A12SC
Atmel
Description
The AT90S1200 is a low-power CMOS 8-bit microcontroller based on the AVR RISC architecture. By executing powerful instructions in a single clock cycle, the AT90S1200 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed. The AVR core combines a rich instruction set with the 32 general purpose working reg- isters. All the 32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent registers to be accessed in one single instruction executed in one clock cycle. The resulting architecture is more code efficient while achieving throughputs up to ten times faster than conventional CISC microcontrollers.
Block Diagram Figure 1.
The AT90S1200 Block Diagram The architecture supports high-level languages efficiently as well as extremely dense assembler code programs. The AT90S1200 provides the following features: 1K byte of In-System Programmable Flash, 64 bytes EEPROM, 15 general purpose I/O lines, 32 general purpose working registers, internal and external interrupts, programmable watchdog timer with internal oscillator, an SPI serial port for program downloading and two software selectable power-saving modes. The Idle Mode stops the CPU while allow-
2 AT90S1200
0838H–AVR–03/02 Document Outline Features Pin Configuration Description Block Diagram Pin Descriptions VCC GND Port B (PB7..PB0) Port D (PD6..PD0) RESET XTAL1 XTAL2 Crystal Oscillator On-chip RC Oscillator Architectural Overview General Purpose Register File ALU – Arithmetic Logic Unit In-System Programmable Flash Program Memory Program and Data Addressing Modes Register Direct, Single Register Rd Register Indirect Register Direct, Two Registers Rd and Rr I/O Direct Relative Program Addressing, RJMP and RCALL Subroutine and Interrupt Hardware Stack EEPROM Data Memory Instruction Execution Timing I/O Memory Status Register – SREG Reset and Interrupt Handling Reset Sources Power-on Reset External Reset Watchdog Reset Interrupt Handling General Interrupt Mask Register – GIMSK Timer/Counter Interrupt Mask Register – TIMSK Timer/Counter Interrupt FLAG Register – TIFR External Interrupts Interrupt Response Time MCU Control Register – MCUCR Sleep Modes Idle Mode Power-down Mode Timer/Counter0 Timer/Counter0 Prescaler Timer/Counter0 Control Register – TCCR0 Timer/Counter0 – TCNT0 Watchdog Timer Watchdog Timer Control Register – WDTCR EEPROM Read/Write Access EEPROM Address Register – EEAR EEPROM Data Register – EEDR EEPROM Control Register – EECR Prevent EEPROM Corruption Analog Comparator Analog Comparator Control and Status Register – ACSR I/O Ports Port B Port B Data Register – PORTB Port B Data Direction Register – DDRB Port B Input Pin Address – PINB Port B as General Digital I/O Alternate Functions of Port B Port B Schematics Port D Port D Data Register – PORTD Port D Data Direction Register – DDRD Port D Input Pins Address – PIND Port D as General Digital I/O Alternate Functions for Port D Port D Schematics Memory Programming Program and Data Memory Lock Bits Fuse Bits Signature Bytes Programming the Flash and EEPROM Parallel Programming Signal Names Enter Programming Mode Chip Erase Programming the Flash Reading the Flash Programming the EEPROM Reading the EEPROM Programming the Fuse Bits Programming the Lock Bits Reading the Fuse and Lock Bits Reading the Signature Bytes Parallel Programming Characteristics Serial Downloading Serial Programming Algorithm Data Polling EEPROM Data Polling Flash Serial Programming Characteristics Electrical Characteristics Absolute Maximum Ratings* DC Characteristics External Clock Drive Waveforms External Clock Drive Typical Characteristics AT90S1200 Register Summary Instruction Set Summary Ordering Information(1) Packaging Information 20P3 20S 20Y Table of Contents
