Datasheet ATtiny11, ATtiny12 - Summary (Atmel) - 2
ПроизводительAtmel
Описание8-bit AVR Microcontroller with 1K Byte Flash
Страниц / Страница15 / 2 — Overview. Table 1. Device. Flash. EEPROM. Register. Voltage Range. …
Формат / Размер файлаPDF / 235 Кб
Overview. Table 1. Device. Flash. EEPROM. Register. Voltage Range. Frequency. ATtiny11/12
Overview Table 1 Device Flash EEPROM Register Voltage Range Frequency ATtiny11/12
21 предложений от 17 поставщиков
Микросхема Микроконтроллер, MCU 8Bit ATtiny AVR RISC 1KB Flash 3.3V/5V 8Pin SOIC EIAJ
ЧипСити
ATTINY11L-2SI
Atmel
136 ₽
ATTINY11L-2SI
ATTINY11L-2SI
ATTINY11L2SI
Atmel
АЦП азиатских производителей
Overview
The ATtiny11/12 is a low-power CMOS 8-bit microcontroller based on the AVR RISC architecture. By executing powerful instructions in a single clock cycle, the ATtiny11/12 achieves throughputs approaching 1 MIPS per MHz, allowing the system designer to optimize power consumption versus processing speed. The AVR core combines a rich instruction set with 32 general-purpose working regis- ters. All the 32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent registers to be accessed in one single instruction executed in one clock cycle. The resulting architecture is more code efficient while achieving throughputs up to ten times faster than conventional CISC microcontrollers.
Table 1.
Parts Description
ATtiny11L 1K - 32 2.7 - 5.5V 0-2 MHz ATtiny11 1K - 32 4.0 - 5.5V 0-6 MHz ATtiny12V 1K 64 B 32 1.8 - 5.5V 0-1.2 MHz ATtiny12L 1K 64 B 32 2.7 - 5.5V 0-4 MHz ATtiny12 1K 64 B 32 4.0 - 5.5V 0-8 MHz The ATtiny11/12 AVR is supported with a full suite of program and system development tools including: macro assemblers, program debugger/simulators, in-circuit emulators, and evaluation kits.
2 ATtiny11/12
1006FS–AVR–06/07 Document Outline Features Pin Configuration Overview ATtiny11 Block Diagram ATtiny12 Block Diagram Pin Descriptions VCC GND Port B (PB5..PB0) XTAL1 XTAL2 RESET Register Summary ATtiny11 Register Summary ATtiny12 Instruction Set Summary Ordering Information ATtiny11 ATtiny12 Packaging Information 8P3 8S2 Datasheet Revision History Rev. 1006F-06/07 Rev. 1006E-07/06 Rev. 1006D-07/03 Rev. 1006C-09/01
