Datasheet ADuM5410, ADuM5411, ADuM5412 (Analog Devices) - 9
ОписаниеQuad-Channel Isolators with Integrated DC-to-DC Converters
Страниц / Страница29 / 9 — Data Sheet. ADuM5410/ADuM5411/ADuM5412. ELECTRICAL CHARACTERISTICS—2.5 V …
Формат / Размер файлаPDF / 856 Кб
Data Sheet. ADuM5410/ADuM5411/ADuM5412. ELECTRICAL CHARACTERISTICS—2.5 V OPERATION DIGITAL ISOLATOR CHANNELS ONLY
Data Sheet ADuM5410/ADuM5411/ADuM5412 ELECTRICAL CHARACTERISTICS—2.5 V OPERATION DIGITAL ISOLATOR CHANNELS ONLY
23 предложений от 10 поставщиков
Изолятор интерфейса, Digital Isolator CMOS 4CH 150Mbps 24Pin SSOP T/R
ADUM5411BRSZ-RL7
от 185 ₽
ADUM5411BRSZ-RL7
549 ₽
Эиком
ADUM5411BRSZ-RL7
от 1 023 ₽
ADUM5411BRSZ-RL7
от 1 339 ₽
All typical specifications are at TA = 25°C, VDD1 = VDD2 = 2.5 V. Minimum/maximum specifications apply over the entire recommended operation range: 2.25 V ≤ VDD1 ≤ 2.75 V, 2.25 V ≤ VDD2 ≤ 2.75 V, −40°C ≤ TA ≤ +105°C, unless otherwise noted. Switching specifications are tested with CL = 15 pF and CMOS signal levels, unless otherwise noted. Supply currents are specified with 50% duty cycle signals.
Table 15. Data Channel Supply Current Specifications 1 Mbps 25 Mbps 100 Mbps Parameter Symbol Min Typ Max Min Typ Max Min Typ Max Unit Test Conditions/Comments
SUPPLY CURRENT CL = 0 pF ADuM5410 IDD1 6.5 9.8 7.3 11.1 10.4 15.5 mA IDD2 2.0 3.6 3.3 5.2 7.3 10.2 mA ADuM5411 IDD1 5.6 10.0 6.4 10.4 9.7 14.5 mA IDD2 3.8 6.55 4.8 7.7 8.3 11.5 mA ADuM5412 IDD1 4.3 7.7 5.4 8.8 8.8 12.7 mA IDD2 5.0 8.4 6.1 9.5 9.5 13.4 mA
Table 16. Switching Specifications Parameter Symbol Min Typ Max Unit Test Conditions/Comments
SWITCHING SPECIFICATIONS Pulse Width PW 6.6 ns Within PWD limit Data Rate 150 Mbps Within PWD limit Propagation Delay tPHL, tPLH 5.0 7.0 14 ns 50% input to 50% output Pulse Width Distortion PWD 0.7 3 ns |tPLH − tPHL| Change vs. Temperature 1.5 ps/°C Propagation Delay Skew tPSK 6.8 ns Between any two units at the same temperature, voltage, and load Channel Matching Codirectional tPSKCD 0.7 3.0 ns Opposing Direction tPSKOD 0.7 3.0 ns Jitter 800 ps p-p 190 ps rms Rev. 0 | Page 9 of 29 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIGRAM REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/5 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—3.3 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—2.5 V OPERATION DIGITAL ISOLATOR CHANNELS ONLY ELECTRICAL CHARACTERISTICS—1.8 V OPERATION DIGITAL ISOLATOR CHANNELS ONLY PACKAGE CHARACTERISTICS REGULATORY APPROVALS INSULATION AND SAFETY RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLES TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION APPLICATIONS INFORMATION PCB LAYOUT THERMAL ANALYSIS PROPAGATION DELAY RELATED PARAMETERS EMI CONSIDERATIONS POWER CONSUMPTION INSULATION LIFETIME Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example OUTLINE DIMENSIONS ORDERING GUIDE
