Линейка продуктов KEEN SIDE
Datasheet ADuM4470, ADuM4471, ADuM4472, ADuM4473, ADuM4474 (Analog Devices) - 10
ОписаниеIsolated Switching Regulator with Quad-Channel Isolators
Страниц / Страница36 / 10 — ADuM4470/ADuM4471/ADuM4472/ADuM4473/ADuM4474. Data Sheet
Формат / Размер файлаPDF / 761 Кб
ADuM4470/ADuM4471/ADuM4472/ADuM4473/ADuM4474 Data Sheet
7 предложений от 7 поставщиков
Изолятор интерфейса, Digital Isolator 4CH 25Mbps 20Pin SOIC W T/R
ADUM4470CRIZ-RL
610 ₽
ADUM4470CRIZ-RL
ADUM4470CRIZ-RL
ADUM4470CRIZ-RL
link to page 26 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11
ADuM4470/ADuM4471/ADuM4472/ADuM4473/ADuM4474 Data Sheet ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/15 V SECONDARY ISOLATED SUPPLY
4.5 V ≤ VDD1 = VDDA ≤ 5.5 V; VREG = VISO = 15 V; VDD2 = 5.0 V; fSW = 500 kHz; al voltages are relative to their respective grounds; see the application schematic in Figure 49. Al minimum/maximum specifications apply over the entire recommended operating range, unless otherwise noted. Al typical specifications are at TA = 25°C, VDD1 = VDDA = 5.0 V, VREG = VISO = 15 V, VDD2 = 5.0 V.
Table 4. DC-to-DC Converter Static Specifications Parameter Symbol Min Typ Max Unit Test Conditions/Comments
DC-TO-DC CONVERTER SUPPLY Isolated Output Voltage VISO 13.8 15 16.2 V IISO = 0 mA, VISO = VFB × (R1 + R2)/R2 Feedback Voltage Setpoint VFB 1.15 1.25 1.37 V IISO = 0 mA VDD2 Linear Regulator Regulator Voltage 4.5 5.0 5.5 V VREG = 7 V to 15 V, IDD2 = 0 mA to 50 mA Dropout Voltage 0.5 1.5 IDD2 = 50 mA Line Regulation VISO (LINE) 1 20 mV/V IISO = 50 mA, V 1 2 DD1 = VDDA = 4.5 V to 5.5 V Load Regulation VISO (LOAD) 1 3 % IISO = 20 mA to 80 mA Output Ripple VISO (RIP) 200 mV p-p 20 MHz bandwidth, COUT = 0.1 µF||47 µF, IISO = 100 mA Output Noise VISO (NOISE) 500 mV p-p 20 MHz bandwidth, COUT = 0.1 µF||47 µF, IISO = 100 mA Switching Frequency fSW 1000 kHz ROC = 50 kΩ 200 kHz ROC = 270 kΩ 192 318 515 kHz VOC = VDD2 (open-loop) Switch On-Resistance RON 0.5 Ω Undervoltage Lockout, VDDA, VDD2 Supplies Positive Going Threshold VUV+ 2.8 V Negative Going Threshold VUV− 2.6 V Hysteresis VUVH 0.2 V DC to 2 Mbps Data Rate3 Maximum Output Supply Current4 IISO (MAX) 100 mA f ≤ 1 MHz, VISO = 5.0 V Efficiency at Maximum Output Current5 78 % IISO = IISO (MAX), f ≤ 1 MHz iCoupler DATA CHANNELS DC to 2 Mbps Data Rate IDD1 Supply Current, No VISO Load IDD1 (Q) IISO = 0 mA, f ≤ 1 MHz ADuM4470 25 45 mA ADuM4471 27 45 mA ADuM4472 29 45 mA ADuM4473 31 45 mA ADuM4474 33 45 mA 25 Mbps Data Rate (CRIZ Grade Only) IDD1 Supply Current, No VISO Load IDD1 (D) ADuM4470 73 mA IISO = 0 mA, CL = 15 pF, f = 12.5 MHz ADuM4471 83 mA IISO = 0 mA, CL = 15 pF, f = 12.5 MHz ADuM4472 93 mA IISO = 0 mA, CL = 15 pF, f = 12.5 MHz ADuM4473 102 mA IISO = 0 mA, CL = 15 pF, f = 12.5 MHz ADuM4474 112 mA IISO = 0 mA, CL = 15 pF, f = 12.5 MHz Available VISO Supply Current6 IISO (LOAD) fSW = 500 kHz ADuM4470 91 mA CL = 15 pF, f = 12.5 MHz ADuM4471 89 mA CL = 15 pF, f = 12.5 MHz ADuM4472 86 mA CL = 15 pF, f = 12.5 MHz ADuM4473 83 mA CL = 15 pF, f = 12.5 MHz ADuM4474 80 mA CL = 15 pF, f = 12.5 MHz IDD1 Supply Current, Full VISO Load 425 mA CL = 0 pF, f = 0 MHz, VDD1 = VDDA = 5 V, IISO = 400 mA Rev. 0 | Page 10 of 36 Document Outline Features Applications Functional Block Diagram General Description Revision History Block Diagrams of I/O Channels Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/15 V Secondary Isolated Supply Package Characteristics Regulatory Approvals (Pending) Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Applications Information Theory of Operation Application Schematics Transformer Design Transformer Turns Ratio Transformer ET Constant Transformer Primary Inductance and Resistance Transformer Isolation Voltage Switching Frequency Transient Response Component Selection Printed Circuit Board (PCB) Layout Thermal Analysis Propagation Delay-Related Parameters DC Correctness and Magnetic Field Immunity Power Consumption Power Considerations Soft Start Mode and Current-Limit Protection Data Channel Power Cycle Insulation Lifetime Outline Dimensions Ordering Guide
