Datasheet LTM2882 (Analog Devices) - 5
ОписаниеDual Isolated RS232 μModule Transceiver + Power
Страниц / Страница22 / 5 — SWITCHING CHARACTERISTICS The. denotes the specifications which apply …
Формат / Размер файлаPDF / 658 Кб
SWITCHING CHARACTERISTICS The. denotes the specifications which apply over the full operating
SWITCHING CHARACTERISTICS The denotes the specifications which apply over the full operating
24 предложений от 15 поставщиков
DGTL ISO 2.5KV 4CH RS232 32LGA. RS232 Digital Isolator 2500Vrms 4 Channel 10Mbps 30kV/µs CMTI 32-BLGA. Digital Isolators
Зенер
Россия и страны ТС
LTM2882CV-5#PBF
от 1 012 ₽
LTM2882CV-5#PBF
1 411 ₽
Эиком
LTM2882CV-5#PBF
от 2 354 ₽
Hi-Tech Circuit Group
LTM2882CV-5#PBF
LTM2882
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. LTM2882-3 VCC = 3.3V, LTM2882-5 VCC = 5.0V, VL = VCC, and GND = GND2 = 0V, ON = VL unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Receiver
tPHLR, tPLHR Receiver Propagation Delay CL = 150pF (Figure 3) l 0.2 0.4 µs tSKEWR Receiver Skew |tPHLR – tPLHR| CL = 150pF (Figure 3) 40 ns tRR, tFR Receiver Rise or Fall Time CL = 150pF (Figure 3) l 60 200 ns
Auxiliary Channel
tPHLL, tPLHL Propagation Delay CL = 15pF, tR and tF < 4ns (Figure 4) l 60 100 ns tRL, tFL Rise or Fall Time CL = 150pF (Figure 4) l 60 200 ns
Power Supply
Power-Up Time ON = ↑ to VCC2(MIN) l 0.2 2 ms
ISOLATION CHARACTERISTICS The
l
VISO Rated Dielectric Insulation Voltage 1 Minute, Derived from 1 Second Test 2500 VRMS 1 Second (Notes 5, 6) ±4400 V Common Mode Transient Immunity VL = ON = 3.3V, VCM = 1kV, ∆t = 33ns (Note 2) 30 kV/µs VIORM Maximum Working Insulation Voltage (Notes 2, 5) 560 VPEAK 400 VRMS Partial Discharge VPR = 1050 VPEAK (Notes 2, 5) 5 pC CTI Comparative Tracking Index IEC 60112 (Note 2) 600 VRMS DTI Depth of Erosion IEC 60112 (Note 2) 0.017 mm Distance Through Insulation (Note 2) 0.06 mm Input to Output Resistance (Notes 2, 5) 109 Ω Input to Output Capacitance (Notes 2, 5) 6 pF Creepage Distance (Notes 2, 5) 9.48 mm
Note 1:
Note 4:
This device includes over-temperature protection that is intended may cause permanent damage to the device. Exposure to any Absolute to protect the device during momentary overload conditions. Junction Maximum Rating condition for extended periods may affect device temperature will exceed 125°C when overtemperature protection is active. reliability and lifetime. Continuous operation above specified maximum operating junction
Note 2:
Guaranteed by design and not subject to production test. temperature may result in device degradation or failure.
Note 3:
Maximum Data Rate is guaranteed by other measured parameters
Note 5:
Tests performed from GND to GND2, all pins shorted each side of and is not tested directly. isolation barrier.
Note 6:
The rated dielectric insulation voltage should not be interpreted as a continuous voltage rating. 2882fh For more information www.linear.com/LTM2882 5 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS SWITCHING CHARACTERISTICS ISOLATION CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS PIN FUNCTIONS BLOCK DIAGRAM APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATIONS RELATED PARTS
