Datasheet LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904 (ON Semiconductor) - 4
ПроизводительON Semiconductor
ОписаниеSingle Supply Dual Operational Amplifiers
Страниц / Страница14 / 4 — LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904. …
Версия32
Формат / Размер файлаPDF / 140 Кб
LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904. ELECTRICAL CHARACTERISTICS. LM258. LM358, LM358E
LM258, LM358, LM358A, LM358E, LM2904, LM2904A, LM2904E, LM2904V, NCV2904 ELECTRICAL CHARACTERISTICS LM258 LM358, LM358E
45 предложений от 27 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM2904D Operational Amplifier, Dual, 2 Amplifier, 700kHz, 0.3V/µs, ± 1.5V to ± 13V, SOIC, 8Pins
LM2904D
7.13 ₽
Эиком
LM2904D
от 51 ₽
LifeElectronics
LM2904D-TI
LM2904D-JF
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
(VCC = 5.0 V, VEE = GND, TA = 25°C, unless otherwise noted.)
LM258 LM358, LM358E LM358A Characteristic Symbol Min Typ Max Min Typ Max Min Typ Max Unit
Input Offset Voltage VIO mV VCC = 5.0 V to 30 V, VIC = 0 V to VCC −1.7 V, VO ] 1.4 V, RS = 0 TA = 25°C − 2.0 5.0 − 2.0 7.0 − 2.0 3.0 TA = Thigh (Note 4) − − 7.0 − − 9.0 − − 5.0 TA = Tlow (Note 4) − − 7.0 − − 9.0 − − 5.0 Average Temperature Coefficient of Input Offset VIO/T − 7.0 − − 7.0 − − 7.0 − V/°C Voltage TA = Thigh to Tlow (Note 4) Input Offset Current IIO − 3.0 30 − 5.0 50 − 5.0 30 nA TA = Thigh to Tlow (Note 4) − − 100 − − 150 − − 75 Input Bias Current IIB − −45 −150 − −45 −250 − −45 −100 TA = Thigh to Tlow (Note 4) − −50 −300 − −50 −500 − −50 −200 Average Temperature Coefficient of Input Offset IIO/T − 10 − − 10 − − 10 − pA/°C Current TA = Thigh to Tlow (Note 4) Input Common Mode Voltage Range (Note 5), VICR 0 − 28.3 0 − 28.3 0 − 28.5 V VCC = 30 V VCC = 30 V, TA = Thigh to Tlow 0 − 28 0 − 28 0 − 28 Differential Input Voltage Range VIDR − − VCC − − VCC − − VCC V Large Signal Open Loop Voltage Gain AVOL V/mV RL = 2.0 k, VCC = 15 V, For Large VO Swing, 50 100 − 25 100 − 25 100 − TA = Thigh to Tlow (Note 4) 25 − − 15 − − 15 − − Channel Separation CS − −120 − − −120 − − −120 − dB 1.0 kHz ≤ f ≤ 20 kHz, Input Referenced Common Mode Rejection CMR 70 85 − 65 70 − 65 70 − dB RS ≤ 10 k Power Supply Rejection PSR 65 100 − 65 100 − 65 100 − dB Output Voltage−High Limit VOH V TA = Thigh to Tlow (Note 4) VCC = 5.0 V, RL = 2.0 k, TA = 25°C 3.3 3.5 − 3.3 3.5 − 3.3 3.5 − VCC = 30 V, RL = 2.0 k 26 − − 26 − − 26 − − VCC = 30 V, RL = 10 k 27 28 − 27 28 − 27 28 − Output Voltage−Low Limit VOL − 5.0 20 − 5.0 20 − 5.0 20 mV VCC = 5.0 V, RL = 10 k, TA = Thigh to Tlow (Note 4) Output Source Current IO+ mA VID = +1.0 V, VCC = 15 V 20 40 − 20 40 − 20 40 − TA = Thigh to Tlow (LM358A Only) 10 − − Output Sink Current IO− VID = −1.0 V, VCC = 15 V 10 20 − 10 20 − 10 20 − mA TA = Thigh to Tlow (LM358A Only) 5.0 − − mA VID = −1.0 V, VO = 200 mV 12 50 − 12 50 − 12 50 − A Output Short Circuit to Ground (Note 6) ISC − 40 60 − 40 60 − 40 60 mA Power Supply Current (Total Device) ICC mA TA = Thigh to Tlow (Note 4) VCC = 30 V, VO = 0 V, RL = ∞ − 1.5 3.0 − 1.5 3.0 − 1.5 2.0 VCC = 5 V, VO = 0 V, RL = ∞ − 0.7 1.2 − 0.7 1.2 − 0.7 1.2 4. LM258: Tlow = −25°C, Thigh = +85°C LM358, LM358A, LM358E: Tlow = 0°C, Thigh = +70°C LM2904/A/E: Tlow = −40°C, Thigh = +105°C LM2904V & NCV2904: Tlow = −40°C, Thigh = +125°C NCV2904 is qualified for automotive use. 5. The input common mode voltage or either input signal voltage should not be allowed to go negative by more than 0.3 V. The upper end of the common mode voltage range is VCC − 1.7 V. 6. Short circuits from the output to VCC can cause excessive heating and eventual destruction. Destructive dissipation can result from simultaneous shorts on all amplifiers.
www.onsemi.com 4
