Datasheet ADR4520, ADR4525, ADR4530, ADR4533, ADR4540, ADR4550 (Analog Devices) - 10
ОписаниеUltra-Low-Noise, High-Accuracy 5.0V Voltage Reference
Страниц / Страница33 / 10 — ADR4520/ADR4525/ADR4530/ADR4533/ADR4540/ADR4550. Data Sheet. PIN …
ВерсияB
ADR4520/ADR4525/ADR4530/ADR4533/ADR4540/ADR4550. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS
ADR4520/ADR4525/ADR4530/ADR4533/ADR4540/ADR4550 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS
33 предложений от 14 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
ADR4533ARZ-R7
215 ₽
Зенер
Россия и страны ТС
ADR4533ARZ-R7
от 301 ₽
ADR4533ARZ-R7
574 ₽
ADR4533ARZ-R7
от 746 ₽
ADR4520/ADR4525/ADR4530/ADR4533/ADR4540/ADR4550 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS ADR4520/ADR4525/ ADR4530/ADR4533/ ADR4540/ADR4550 NIC 1 8 DNC VIN 2 7 NIC NIC 3 6 V TOP VIEW OUT GND (Not to Scale) 4 5 NIC NOTES 1. NIC = NOT INTERNALLY CONNECTED.
002
THIS PIN IS NOT CONNECTED INTERNALLY. 2. DNC = DO NOT CONNECT. DO NOT CONNECT TO THIS PIN.
10203- Figure 2. Pin Configuration
Table 11. Pin Function Descriptions Pin No. Mnemonic Description
1 NIC Not Internally Connected. This pin is not connected internally. 2 VIN Input Voltage Connection. 3 NIC Not Internally Connected. This pin is not connected internally. 4 GND Ground. 5 NIC Not Internally Connected. This pin is not connected internally. 6 VOUT Output Voltage. 7 NIC Not Internally Connected. This pin is not connected internally. 8 DNC Do Not Connect. Do not connect to this pin. Rev. A | Page 10 of 33 Document Outline Features Applications Pin Configuration General Description Revision History Specifications ADR4520 Electrical Characteristics ADR4525 Electrical Characteristics ADR4530 Electrical Characteristics ADR4533 Electrical Characteristics ADR4540 Electrical Characteristics ADR4550 Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics ADR4520 ADR4525 ADR4530 ADR4533 ADR4540 ADR4550 Terminology Theory of Operation Long-Term Drift Power Dissipation Applications Information Basic Voltage Reference Connection Input and Output Capacitors Input Capacitors Output Capacitors Location of Reference in System Sample Applications Bipolar Output Reference Boosted Output Current Reference Outline Dimensions Ordering Guide Automotive Products
