Линейка продуктов KEEN SIDE
Datasheet LTC6652 (Analog Devices) - 3
ОписаниеPrecision Low Drift Low Noise Buffered Reference
Страниц / Страница20 / 3 — orDer inForMation. LEAD FREE FINISH. PART MARKING*. PACKAGE DESCRIPTION. …
Формат / Размер файлаPDF / 561 Кб
orDer inForMation. LEAD FREE FINISH. PART MARKING*. PACKAGE DESCRIPTION. SPECIFIED TEMPERATURE RANGE. available options
orDer inForMation LEAD FREE FINISH PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE available options
36 предложений от 17 поставщиков
IC: источник опорного напряжения; 1,25В; ±0,05%; MSOP8; 5мА
LTC6652AHMS8-1.25#TRPBF
322 ₽
727GS
LTC6652AHMS8-1.25#PBF
от 736 ₽
Элитан
LTC6652AHMS8-1.25
960 ₽
от 966 ₽
LTC6652
LTC6652AHLS8-2.5#PBF† 665225 8-Lead Ceramic LCC 5mm × 5mm –40°C to 125°C LTC6652BHLS8-2.5#PBF† 665225 8-Lead Ceramic LCC 5mm × 5mm –40°C to 125°C LTC6652AHLS8-4.096#PBF† 524096 8-Lead Ceramic LCC 5mm × 5mm –40°C to 125°C LTC6652BHLS8-4.096#PBF† 524096 8-Lead Ceramic LCC 5mm × 5mm –40°C to 125°C LTC6652AHLS8-5#PBF† 66525 8-Lead Ceramic LCC 5mm × 5mm –40°C to 125°C LTC6652BHLS8-5#PBF† 66525 8-Lead Ceramic LCC 5mm × 5mm –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ †This product is only offered in trays. For more information go to: http://www.linear.com/packaging/
available options OUTPUT VOLTAGE INITIAL ACCURACY TEMPERATURE COEFFICIENT PART NUMBER**
1.250 0.05% 5ppm/°C LTC6652AHMS8-1.25 0.1% 10ppm/°C LTC6652BHMS8-1.25 2.048 0.05% 5ppm/°C LTC6652AHMS8-2.048 0.1% 10ppm/°C LTC6652BHMS8-2.048 2.500 0.05% 5ppm/°C LTC6652AHMS8-2.5 0.1% 10ppm/°C LTC6652BHMS8-2.5 0.05% 5ppm/°C LTC6652AHLS8-2.5 0.1% 8ppm/°C LTC6652BHLS8-2.5 3.000 0.05% 5ppm/°C LTC6652AHMS8-3 0.1% 10ppm/°C LTC6652BHMS8-3 3.300 0.05% 5ppm/°C LTC6652AHMS8-3.3 0.1% 10ppm/°C LTC6652BHMS8-3.3 4.096 0.05% 5ppm/°C LTC6652AHMS8-4.096 0.1% 10ppm/°C LTC6652BHMS8-4.096 0.05% 5ppm/°C LTC6652AHLS8-4.096 0.1% 8ppm/°C LTC6652BHLS8-4.096 5.000 0.05% 5ppm/°C LTC6652AHMS8-5 0.1% 10ppm/°C LTC6652BHMS8-5 0.05% 5ppm/°C LTC6652AHLS8-5 0.1% 8ppm/°C LTC6652BHLS8-5 **See Order Information section for complete part number listing.
e lectrical characteristics The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C, VIN = VOUT + 0.5V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Output Voltage LTC6652A –0.05 0.05 % LTC6652B –0.1 0.1 % Output Voltage Temperature Coefficient LTC6652A l 2 5 ppm/°C (Note 3) LTC6652BMS8 l 4 10 ppm/°C LTC6652BLS8 l 4 8 ppm/°C Line Regulation VOUT + 0.5V ≤ VIN ≤ 13.2V, SHDN = VIN 2 50 ppm/V l 80 ppm/V 6652fg For more information www.linear.com/LTC6652 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
