Datasheet ADR293-EP (Analog Devices) - 3
ОписаниеLow Noise, Micropower 5.0 V Precision Voltage Reference
Страниц / Страница12 / 3 — Enhanced Product. ADR293-EP. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. …
ВерсияA
Формат / Размер файлаPDF / 207 Кб
Enhanced Product. ADR293-EP. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
Enhanced Product ADR293-EP SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter Symbol Conditions Min Typ Max Unit
28 предложений от 13 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
ADR293TRUZ-EP-R7
225 ₽
ADR293TRUZ-EP-R7
571 ₽
ADR293TRUZ-EP
Hi-Tech Circuit Group
ADR293TRUZ-EP
VS = 6.0 V, TA = 25°C, unless otherwise noted.
Table 1. Parameter Symbol Conditions Min Typ Max Unit
OUTPUT VOLTAGE VOUT IOUT = 0 mA T Grade 4.990 5.000 5.010 V INITIAL ACCURACY IOUT = 0 mA T Grade –10 +10 mV 0.20 % LINE REGULATION ΔVOUT /ΔVIN 6.0 V to 15 V, IOUT = 0 mA T Grade 40 150 ppm/V LOAD REGULATION ΔVOUT /ΔILOAD VS = 6.0 V, IOUT = 0 mA to 5 mA T Grade 30 150 ppm/mA LONG-TERM STABILITY ΔVOUT After 1000 hours of operation @ 125°C 50 ppm VOLTAGE NOISE eN p-p f = 0.1 Hz to 10 Hz 15 μV p-p VOLTAGE NOISE DENSITY eN f = 1 kHz 640 nV/√Hz VS = 6.0 V, TA = −25°C to +85°C, unless otherwise noted.
Table 2. Parameter Symbol Conditions Min Typ Max Unit
TEMPERATURE COEFFICIENT TCVOUT IOUT = 0 mA T Grade 10 25 ppm/°C LINE REGULATION ΔVOUT/ΔVIN 6.0 V to 15 V, IOUT = 0 mA T Grade 50 200 ppm/V LOAD REGULATION ΔVOUT/ΔILOAD VS = 6.0 V, IOUT = 0 mA to 5 mA T Grade 30 200 ppm/mA Rev. A | Page 3 of 12 Document Outline Features Enhanced Product Features Applications Pin Configuration General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide
