Datasheet ADR291W (Analog Devices) - 6
ОписаниеLow Noise Micropower Precision Voltage Reference (2.5 V)
Страниц / Страница8 / 6 — ADR291W. TERMINOLOGY Line Regulation. Temperature Coefficient. Load …
Формат / Размер файлаPDF / 128 Кб
ADR291W. TERMINOLOGY Line Regulation. Temperature Coefficient. Load Regulation. NC = No Connect. Long-Term Stability
ADR291W TERMINOLOGY Line Regulation Temperature Coefficient Load Regulation NC = No Connect Long-Term Stability
72 предложений от 30 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
ADR291GRZ
от 112 ₽
Эиком
ADR291GRZ-REEL
от 860 ₽
ADR291GRZ-REEL7
от 880 ₽
SUV System
ADR291GRZ
Line regulation refers to the change in output voltage due to a Temperature coefficient is the change of output voltage over specified change in input voltage. It includes the effects of self- the operating temperature change, normalized by the output heating. Line regulation is expressed as percent per volt, parts voltage at 25°C, expressed in ppm/°C. The equation follows: per million per volt, or microvolts per volt change in input TCV  V T  V T ppm/C     OUT 2 OUT 1 6  10 voltage. O V 25CT T  OUT 2 1
Load Regulation
where: The change in output voltage is due to a specified change in VOUT (25°C) = VOUT at 25°C. load current and includes the effects of self-heating. Load VOUT (T1) = VOUT at Temperature 1. regulation is expressed in microvolts per milliampere, parts per VOUT (T2) = VOUT at Temperature 2. million per milliampere, or ohms of dc output resistance.
There are internal connections at NC pins that are reserved for Long-term stability refers to the typical shift of output voltage manufacturing purposes. Users should not connect anything at at 25°C on a sample of parts subjected to a test of 1000 hours the NC pins. at 125°C.
Thermally Induced Output Voltage Hysteresis
V  V t V t Thermally induced output voltage hysteresis is defined as the OUT OUT 0    OUT 1  V t V t change of output voltage after the device is cycled through  V   ppm  OUT 0    OUT 1 6  OUT temperatures from +25°C to −40°C, then to +85°C, and back to V t OUT 0  10 +25°C. This is a typical value from a sample of parts put where: through such a cycle. VOUT (t0) = VOUT at 25°C at Time 0. V  V 25 ( C)  V OUT  V HYS OUT OUT_TC OUT (t1) = VOUT at 25°C after 1000 hours of operation at 125°C. V 25 ( C)  V OUT OUT_TC 6 V [ppm]  10 ΟUT HYS V 25 ( C) OUT where: VOUT (25°C) = VOUT at 25°C. VOUT–TC = VOUT at 25°C after temperature cycle from +25°C to −40°C, then to +85°C, and back to +25°C. Rev. 0 | Page 6 of 8 Document Outline Features Applications Connection Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Outline Dimensions Ordering Guide
