Datasheet LT1019 (Analog Devices) - 6
ОписаниеPrecision Reference
Страниц / Страница12 / 6 — TYPICAL PERFOR A CE CH. ARA TERISTICS. LT1019-2.5* Stability with. Temp …
Формат / Размер файлаPDF / 164 Кб
TYPICAL PERFOR A CE CH. ARA TERISTICS. LT1019-2.5* Stability with. Temp Pin Voltage. Line Regulation. Output Capacitance
TYPICAL PERFOR A CE CH ARA TERISTICS LT1019-2.5* Stability with Temp Pin Voltage Line Regulation Output Capacitance
41 предложений от 24 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
LT1019CN8-5PBF
от 1 591 ₽
TradeElectronics
LT1019CN85
LT1019CN8-5
МосЧип
LT1019CN85.0
LT1019
W U TYPICAL PERFOR A CE CH C ARA TERISTICS LT1019-2.5* Stability with Temp Pin Voltage Line Regulation Output Capacitance
0.90 140 10 IOUT 0.85 120 TJ = 25°C V) 0.80 µ 100 1 F) 0.75 80 µ REGION OF POSSIBLE 0.70 60 INSTABILITY 0.1 LT1019-10 0.65 40 0.60 20 VOLTAGE (V) 0.01 LT1019-2.5 0.55 0 LT1019-5 OUTPUT CAPACITOR ( 0.50 –10 OUTPUT VOLTAGE CHANGE ( 0.001 0.45 –20 0.40 –30 0.0001 –50 –25 0 25 50 75 100 125 0 5 10 15 20 25 30 35 40 20 15 10 5 0 5 10 15 20 JUNCTION TEMPERATURE (°C) INPUT VOLTAGE (V) SINK CURRENT SOURCE CURRENT OUTPUT CURRENT (mA) LT1019 • TPC10 LT1019 • TPC11 1019 G12 *LT1019-4.5/LT1019-5/LT1019-10 ARE STABLE WITH ALL LOAD CAPACITANCE.
W BLOCK DIAGRA
R1 LT1019-2.5 = 11k LT1019-4.5 = 13.9k LT1019-5 = 16k LT1019-10 = 37.1k VIN R3 80k – TRIM R2 1.188V VOUT LT1019-4.5, LT1019-5, + LT1019-10 = 5k LT1019-2.5 = 10k GND LT1019 • BD
U U W U APPLICATIO S I FOR ATIO Line and Load Regulation
Two separate thermal effects are evident in monolithic circuits. One is a gradient effect, where power dissipation Line regulation on the LT1019 is nearly perfect. A 10V on the die creates temperature gradients. These gradients change in input voltage causes a typical output shift of less can cause output voltage shifts even if the overall tempera- than 5ppm. Load regulation (sourcing current) is nearly as ture coefficient of the reference is zero. The LT1019, unlike good. A 5mA change in load current shifts output voltage previous references, specifies thermal regulation caused by only 100µV. These are electrical effects, measured with by die temperature gradients.The specification is low duty cycle pulses to eliminate heating effects. In real 0.5ppm/mW. To calculate the effect on output voltage, world applications, the thermal effects of load and line simply multiply the change in device power dissipation by changes must be considered. 1019fd 6
