Datasheet LTM8001 (Analog Devices) - 6
Описание | 36VIN, 5A μModule Regulator with 5-Output Configurable LDO Array |
Страниц / Страница | 28 / 6 — Typical perForMance characTerisTics. (TA = 25°C unless otherwise noted. … |
Формат / Размер файла | PDF / 400 Кб |
Язык документа | английский |
Typical perForMance characTerisTics. (TA = 25°C unless otherwise noted. Configured per Table 1, where applicable.)
27 предложений от 15 поставщиков Источники питания - Для монтажа на плату Преобразователи DC/DC |
| LTM8001EY#PBF Linear Technology | от 156 ₽ | |
| LTM8001EY#PBF Linear Technology | 2 013 ₽ | |
| LTM8001EY#PBF Analog Devices | от 4 844 ₽ | |
| LTM8001EY#PBF Analog Devices | от 4 862 ₽ | |
LTM8001
Typical perForMance characTerisTics (TA = 25°C unless otherwise noted. Configured per Table 1, where applicable.) Input Current vs Output Current, Input Current vs Output Current, Minimum VIN0 vs Output Current, VOUT0 = 18V VOUT0 = 24V VOUT0 = 3.3V and Below
4.0 5.0 7 3.5 4.5 4.0 3.0 3.5 6 2.5 3.0 VOLTAGE (V) 2.0 2.5 IN0 1.5 2.0 5 INPUT CURRENT (A) INPUT CURRENT (A) 1.5 1.0 1.0 MINIMUM V 0.5 VINO = 28V 0.5 VINO = 28V VINO = 36V VINO = 36V 0 0 4 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 VOUT0 CURRENT (A) VOUT0 CURRENT (A) VOUT0 CURRENT (A) 8001 G13 8001 G14 8001 G1
Minimum VIN0 vs Output Current, Minimum VIN0 vs Output Current, Minimum VIN0 vs Output Current, VOUT0 = 5V VOUT0 = 8V VOUT0 = 12V
6.80 9.85 13.95 13.90 6.75 9.80 13.85 VOLTAGE (V) VOLTAGE (V) VOLTAGE (V) 13.80 IN0 IN0 IN0 6.70 9.75 13.75 MINIMUM V MINIMUM V MINIMUM V 13.70 6.65 9.70 13.65 0 1 2 3 4 5 0 1 2 3 4 5 0 1 2 3 4 5 VOUT0 CURRENT (A) VOUT0 CURRENT (A) VOUT0 CURRENT (A) 8001 G16 8001 G17 8001 G18
Minimum VIN0 vs Output Current, Minimum VIN0 vs Output Current, Output Voltage vs Output Current, VOUT0 = 18V VOUT0 = 24V VOUT0 = 2.5V
19.71 26.10 3.5 26.05 19.70 3.0 26.00 19.69 25.95 2.5 25.90 19.68 2.0 VOLTAGE (V) VOLTAGE (V) 25.85 IN0 IN0 25.80 19.67 1.5 25.75 19.66 25.70 OUTPUT VOLTAGE (V) 1.0 MINIMUM V MINIMUM V 25.65 19.65 0.5 25.60 19.64 25.55 0 0 1 2 3 4 5 0 1 2 3 4 5 –10 –5 0 5 10 VOUT0 CURRENT (A) VOUT0 CURRENT (A) LOAD CURRENT (A) 8001 G19 8001 G20 8001 G21 8001fd 6 For more information www.linear.com/LTM8001 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photo Revision History Typical Application Related Parts
