Datasheet LTM4630-1 (Analog Devices) - 2
ОписаниеDual 18A or Single 36A μModule (Power Module) Regulator with 0.8% DC and 3% Transient Accuracy
Страниц / Страница38 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. PART MARKING*. PACKAGE. MSL. TOTAL DC. TEMPERATURE
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION PART MARKING* PACKAGE MSL TOTAL DC TEMPERATURE
17 предложений от 11 поставщиков
DC DC CNVRTR 0.6-1.8V 0.6-1.8V. Non-Isolated PoL Module DC DC Converter 2 Output 0.6 ~ 1.8V 0.6 ~ 1.8V 18A, 18A...
Рутоника
LTM4630IY-1A
5 468 ₽
LTM4630IY-1A
5 970 ₽
Элитан
LTM4630IY-1A
12 205 ₽
727GS
LTM4630IY-1A
LTM4630-1
V TOP VIEW IN ..–0.3V to 16V TEMP EXTV V CC SW1, VSW2 ..–1V to 16V M PGOOD1, PGOOD2, RUN1, RUN2, L INTVCC, EXTVCC .. –0.3V to 6V VIN K MODE_PLLIN, fSET, TRACK1, TRACK2, J DIFFOUT, PHASMD ... –0.3V to INTVCC H INTV V CLKOUT CC OUT1, VOUT2, VOUTS1, VOUTS2 (Note 6) .. –0.3V to 6V SW1 SW2 PGOOD1 DIFFP, DIFFN ... –0.3V to INTV G CC PHASMD RUN1 SGND PGOOD2 RUN2 INTV F MODE_PLLIN CC Peak Output Current ..100mA GND COMP1 COMP2 DIFFOUT DIFFP Internal Operating Temperature Range E DIFFN TRACK1 SGND VFB2 TRACK2 V GND FB1 (Note 2) ... –40°C to 125°C D f V SET SGND OUTS2 Storage Temperature Range .. –55°C to 125°C C VOUTS1 Peak Package Body Temperature .. 245°C B VOUT1 V GND OUT2 A 1 2 3 4 5 6 7 8 9 10 11 12 BGA PACKAGE 144-LEAD (16mm × 16mm × 5.01mm) TJMAX = 125°C, θJA = 7°C/W, θJCbottom = 1.5°C/W, θJCtop = 3.7°C/W, θJB + θJBA ≅ 7°C/W θ VALUES DEFINED PER JESD 51-12 WEIGHT = 3.5g
ORDER INFORMATION PART MARKING* PACKAGE MSL TOTAL DC TEMPERATURE  PART NUMBER PAD OR BALL FINISH DEVICE FINISH CODE TYPE RATING ACCURACY RANGE (Note 2)
LTM4630EY-1A#PBF SAC305 (RoHS) LTM4630Y-1 e4 BGA 3 ±0.8% –40°C to 125°C LTM4630IY-1A#PBF SAC305 (RoHS) LTM4630Y-1 e4 BGA 3 ±0.8% –40°C to 125°C LTM4630EY-1B#PBF SAC305 (RoHS) LTM4630Y-1 e4 BGA 3 ±1.5% –40°C to 125°C LTM4630IY-1B#PBF SAC305 (RoHS) LTM4630Y-1 e4 BGA 3 ±1.5% –40°C to 125°C Consult Marketing for parts specified with wider operating temperature • Recommended LGA and BGA PCB Assembly and Manufacturing ranges. *Device temperature grade is indicated by a label on the shipping Procedures: container. Pad or ball finish code is per IPC/JEDEC J-STD-609. www.linear.com/umodule/pcbassembly • Terminal Finish Part Marking: • LGA and BGA Package and Tray Drawings: www.linear.com/leadfree www.linear.com/packaging 46301fa 2 For more information www.linear.com/LTM4630-1 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Operation Applications Information Package Description Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Operation Applications Information Output Total DC Accuracy and AC Transient Performance Applications Information Typical Applications Package Description Revision History Package Photo Design Resources Related Parts
