Datasheet LTM4611 (Analog Devices) - 5
ОписаниеUltralow VIN, 15A DC/DC µModule Regulator
Страниц / Страница30 / 5 — elecTrical characTerisTics. Note 1:. Note 2:. Note 3:. Note 4:. Note 5:. …
Формат / Размер файлаPDF / 493 Кб
elecTrical characTerisTics. Note 1:. Note 2:. Note 3:. Note 4:. Note 5:. Typical perForMance characTerisTics
elecTrical characTerisTics Note 1: Note 2: Note 3: Note 4: Note 5: Typical perForMance characTerisTics
32 предложений от 14 поставщиков
Источники питания - Для монтажа на плату Преобразователи DC/DC
727GS
LTM4611IV#PBF
от 1.39 ₽
LTM4611IV#PBF
1 686 ₽
Эиком
LTM4611IV#PBF
от 7 556 ₽
ТаймЧипс
LTM4611IV#PBF
LTM4611
Stresses beyond those listed under Absolute Maximum Ratings range. Note that the maximum ambient temperature consistent with may cause permanent damage to the device. Exposure to any Absolute these specifications is determined by specific operating conditions in Maximum Rating condition for extended periods may affect device conjunction with board layout, the rated package thermal resistance and reliability and lifetime. other environmental factors.
Note 2:
The LTM4611 is tested under pulsed load conditions such that
Note 3:
Consistent with Pb-free 260°C peak IR reflow soldering profiles. TJ ≈ TA. The LTM4611E is guaranteed to meet performance specifications See Application Note 100. over the 0°C to 125°C operating junction temperature (TJ) range.
Note 4:
See output current derating curves for different VIN, VOUT and TA. Specifications over the full –40°C to 125°C operating junction temperature
Note 5:
The minimum on-time condition is specified for a peak-to-peak range are assured by design, characterization and correlation with inductor ripple current of ~40% of I statistical process controls. The LTM4611I is guaranteed to meet MAX Load. (See the Typical Applications section) specifications over the full –40°C to 125°C operating junction temperature
Typical perForMance characTerisTics Efficiency vs Load Current at Efficiency vs Load Current at Efficiency vs Load Current at 1.5VIN, Forced Continuous Mode 1.8VIN, Forced Continuous Mode 2.5VIN, Forced Continuous Mode
95 95 95 1.2VOUT 1.0VOUT 0.9VOUT 90 0.8VOUT 90 90 85 85 85 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 1.5VOUT 80 80 1.2VOUT 80 1.0VOUT 1.8VOUT 1.0VOUT 0.9VOUT 1.5VOUT 0.9VOUT 0.8VOUT 1.2VOUT 0.8VOUT 75 75 75 0 3 6 9 12 15 0 3 6 9 12 15 0 3 6 9 12 15 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 4611 G01 4611 G02 4611 G03
Efficiency vs Load Current at Efficiency vs Load Current at 3.3VIN, Forced Continuous Mode 5VIN, Forced Continuous Mode Burst Mode Efficiency
95 95 95 90 85 3.3VIN TO 1.5VOUT 90 90 80 75 70 5VIN TO 1VOUT 65 85 85 60 55 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 50 80 2.5VOUT 80 3.3V 1.2V OUT OUT 45 1.8VOUT 1.0VOUT 2.5V 1.0V OUT OUT 40 1.5VOUT 0.9VOUT 1.8V 0.9V OUT OUT 1.2V 35 OUT 0.8VOUT 1.5V 0.8V OUT OUT 75 75 30 0 3 6 9 12 15 0 3 6 9 12 15 0.1 1 10 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 4611 G06 4611 G04 4611 G05 4611fb For more information www.linear.com/LTM4611 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Photograph Package Description Revision History Typical Application Related Parts
