Datasheet LTM4606 (Analog Devices) - 4
ОписаниеUltralow EMI 28VIN, 6A DC/DC μModule Regulator
Страниц / Страница28 / 4 — elecTrical characTerisTics. The. denotes the specifications which apply …
Формат / Размер файлаPDF / 616 Кб
elecTrical characTerisTics. The. denotes the specifications which apply over the specified internal
elecTrical characTerisTics The denotes the specifications which apply over the specified internal
25 предложений от 10 поставщиков
, Conv DC-DC 4.5V to 28V Step Down Single-Out 0.6V to 5V 6A uModule Automotive 133-Pin BGA Tray
LTM4606IY#PBF
от 815 ₽
LTM4606IY
1 687 ₽
Элитан
LTM4606IY
5 945 ₽
LTM4606IY#PBF
от 6 230 ₽
LTM4606
l
denotes the specifications which apply over the specified internal operating temperature range, otherwise specifications are at TA = 25°C (Note 2). VIN = 12V, unless otherwise noted. Per typical application (front page) configuration, RFB = 40.2k. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Control Section
VFB Voltage at VFB Pin IOUT = 0A, VOUT = 1.5V l 0.591 0.6 0.609 V VRUN RUN Pin On/Off Threshold 1 1.5 1.9 V ITRACK/SS Soft-Start Charging Current VTRACK/SS = 0V –1 –1.5 –2 µA VFCB Forced Continuous Threshold 0.57 0.6 0.63 V IFCB Forced Continuous Pin Current VFCB = 0V –1 –2 µA tON(MIN) Minimum On Time (Note 3) 50 100 ns tOFF(MIN) Minimum Off Time (Note 3) 250 400 ns RPLLIN PLLIN Input Resistor 50 kW IDRVCC Current into DRVCC Pin VOUT = 1.5V, IOUT = 1A, DRVCC = 5V 15 25 mA RFBHI Resistor Between VOUT and VFB Pins 60.098 60.4 60.702 kW VRUN(MAX) Maximum RUN Pin Voltage 5.1V Zener Clamp 5 V
Margin Section
VMPGM Margin Reference Voltage 1.18 V VMARG0, VMARG1 MARG0, MARG1 Voltage Threshold 1.4 V
PGOOD
DVFBH PGOOD Upper Threshold VFB Rising 7 10 13 % DVFBL PGOOD Lower Threshold VFB Falling –7 –10 –13 % DVFB(HYS) PGOOD Hysteresis VFB Returning 1.5 % VPGL PGOOD Low Voltage IPGOOD = 5mA 0.15 0.4 V
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings –40°C to 125°C internal operating temperature range. The LTM4606MP may cause permanent damage to the device. Exposure to any Absolute is guaranteed and tested over the –55°C to 125°C internal operating Maximum Rating condition for extended periods may affect device temperature range. Note that the maximum ambient temperature reliability and lifetime. consistent with these specifications is determined by specific operating
Note 2:
The LTM4606E is guaranteed to meet performance specifications conditions in conjunction with board layout, the rated package thermal over the 0°C to 125°C internal operating temperature range. Specifications resistance and other environmental factors. over the –40°C to 125°C internal operating temperature range are assured
Note 3:
100% tested at die level only. by design, characterization and correlation with statistical process
Note 4:
See output current derating curves for different VIN, VOUT and TA. controls. The LTM4606I is guaranteed to meet specifications over the 4606fd 4 For more information www.linear.com/LTM4606 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Revision History Package Photograph Related Parts
