Datasheet LTC4013 (Analog Devices) - 38
Описание60V Synchronous Buck Multi-Chemistry Battery Charger
Страниц / Страница38 / 38 — TYPICAL APPLICATION. Figure 22. 24V 5A 6 Cell Lead Acid Charger with …
TYPICAL APPLICATION. Figure 22. 24V 5A 6 Cell Lead Acid Charger with Absorption and Equalization Charging
TYPICAL APPLICATION Figure 22 24V 5A 6 Cell Lead Acid Charger with Absorption and Equalization Charging
22 предложений от 10 поставщиков
, 60V Synchronous Buck Multi-Chemistry Battery Charger
LTC4013EUFD#TRPBF
от 169 ₽
727GS
LTC4013EUFD#TRPBF
от 416 ₽
IC Home
LTC4013EUFD#TRPBF
843 ₽
LTC4013EUFD#TRPBF
905 ₽
LTC4013
TYPICAL APPLICATION Figure 22. 24V 5A 6 Cell Lead Acid Charger with Absorption and Equalization Charging
DCIN M1 24V C2/10 C9 C1 D4 10µF×2 68µF 4 STAGE CHARGING WITH 4.7µF 13.6V FLOAT, 14.2V ABSORPTION AND 15.0V EQUALIZATION INFET VIN_S VIN 3.3 HR TIMEOUT DCIN BST C15 R1 C3 0.15µF 665k 0.1µF TG M2 ENAB SW R3 BG M3 40.2k MPPT D1 C13 L1 B0540W 4.7µF 6.8µH R18 R17 7.5k 7.5k INTV INTVCC CC FBOC D2 D3 PGND RED GREEN LTC4013 SENSE STAT0 RSENSE STAT1 10m BAT BAT RFB2 ISMON 499k FB C16-18 MODE1 RFB1 22µF×3 100k C19 C23 BATTERY INTVCC MODE2 NTC INTVCC 0.1µF 220µF SYNC CLKOUT SGND M1, M2, M3 VISHAY SiS434DN L1 WURTH 7443340680 RT TMR LB ITH C1 4.7µF 50V C2, C10 10µF, 50V R23 C31 R24 R22 C16-C18 22µF 25V 86.6k 0.22µF 86.6k 23.2k C23 220µF 25V C9 PANASONIC 68µF 50V EEHZA1H680P C29 D4 CMDZZ5245B 4.7nF 4013 TA05
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC4020 55V Buck-Boost Multi-Chemistry Battery Charger Li-Ion and Lead Acid Charge Algorithms LTC4000/LTC4000-1 High Voltage High Current Controller for Battery 3V to 60V Input and Output Voltage. Pair with a DC/DC Converter. LTC4000- 1 Charging Has MPPT LTC4015 Multichemistry Buck Battery Charger Controller 4.5V to 35V Synchronous Buck Battery Charger with Multiple System with Digital Telemetry System Monitors and Coulomb Counter LTC3305 Lead Acid Battery Balancer Balance up to Four 12V Lead Acid Batteries in Series. Stand Alone Operation LT8710 Synchronous SEPIC/ Inverting/Boost Controller 2, 3-Stage Lead Acid Charger with C/10 Termination with Output Current Control LT3652/LTC3652HV 2A Battery Charger with Power Tracking Multi-Chemistry, Onboard Termination, Input Supply Voltage Regulation Loop for Peak Power Tracking. 4.95V to 34V input Up to 2A Charger Current. LT3651-4.x/LT3651-8.x Monolithic 4A Switch Mode Synchronous Li-Ion Standalone, 4.75V ≤ VIN ≤ 32V (40V Abs Max), 4A, Programmable Charge Battery Charger Current Timer or C/10 Termination LT8490 High Voltage High Current Buck-Boost Controller 6V to 80V Input and Output Voltage. Single Inductor. MPPT Battery Charger 4013fa 38 LT 0218 REV A • PRINTED IN USA ANALOG DEVICES, INC. 2016
