Datasheet LTC4015 (Analog Devices) - 7 Производитель Analog Devices Описание Multichemistry Buck Battery Charger Controller with Digital Telemetry System Страниц / Страница 76 / 7 — ELECTRICAL. CHARACTERISTICS The. denotes the specifications which apply … Формат / Размер файла PDF / 1.6 Мб Язык документа английский
ELECTRICAL. CHARACTERISTICS The. denotes the specifications which apply over the specified operating
Скачать PDF
33 предложений от 15 поставщиков
Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC4015EUHF#TRPBF Battery Charger for 9 Cells of Lead Acid, LiFePO4, Li-Ion, Li-Pol battery, 35Vin, 20A...
LTC4015EUHF#TRPBF Analog Devices 728 ₽ КупитьLTC4015EUHF#TRPBF Analog Devices 1 028 ₽ КупитьLTC4015EUHF#TRPBF Analog Devices по запросу КупитьLTC4015EUHF#TRPBF Analog Devices по запросу Купить
Модельный ряд для этого даташита Текстовая версия документа LTC4015ELECTRICAL CHARACTERISTICS The ldenotes the specifications which apply over the specified operating junction temperature range, otherwise specifications are at TA = 25°C. (Note 2), DVCC = 3.3V, UVCLFB = 1.5; CELLS1 = INTVCC; EQ, MPPT, CELLS0, CELLS2, CHEM0, CHEM1 = 0; RT = 95.3k; RCCREF = 301k, RNTCBIAS = RNTC = 10k; BATSENS = CSN = CSP; DRVCC = INTVCC; SYS = CLP = CLN. Conditions: Charging; VIN = 12V, SYS = 12V, BATSENS = 7.4V …..Battery Only; VIN = 0V, SYS = 8.4V, BATSENS = 8.4V SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Oscillator fOSC Switching Frequency RT = 95.3k l 475 500 525 kHz fMAX Maximum Programmable Frequency RT = 47.5k 1 MHz fMIN Minimum Programmable Frequency RT = 237k 200 kHzGate Drivers RUP-TG TG Pull-Up On-Resistance 2.0 Ω RDOWN-TG TG Pull-Down On-Resistance 0.5 Ω RUP-BG BG Pull-Up On-Resistance 2.0 Ω RDOWN-BG TG Pull-Down On-Resistance 0.5 Ω tR-TG TG 10% to 90% Rise Time CLOAD = 3.3nF 20 ns tF-TG TG 90% to 10% Fall Time CLOAD = 3.3nF 10 ns tR-BG BG 10% to 90% Rise Time CLOAD = 3.3nF 20 ns tF-BG BG 90% to 10% Fall Time CLOAD = 3.3nF 10 ns tNO Non-Overlap Time 60 ns tON(MIN) Minimum On-Time 140 ns DCMAX Maximum Duty Cycle 98.4 %VC Error Amplifier gm Transconductance to VC pin gm (VCSP–CSM) (Constant-Current) 4.10 mmho gm (VBATSENS) (Constant-Voltage Lithium) 2 Cell; (gm = 1.06 –3 • 2/(7 • Cell Count) 0.15 mmho gm (VBATSENS) (Constant-Voltage LA) 6 Cell; (gm = 1.06 –3 • 3/(7 • Cell Count) 0.08 mmho gm (VUVCLFB) (Input Voltage Regulation) 1.06 mmho gm (VCLP–CLM) (Input Current Limiting) 4.10 mmhoTelemetry A/D Measurement Subsystem, Battery Only Mode VERR Measurement Error (Note 6) VIN = 1V ±100 mV VIN = 35V ±1.5 % VSYS = 2.5V ±100 mV VSYS = 35V ±1.5 % VBAT = 1.75V, 1 Cell Li-Ion ±50 mV VBAT = 35V, 9 Cell Li-Ion ±1.5 % VCLP–CLN = 0mV ±200 µV VCLP–CLN = 32mV ±2.5 % VCSP–CSN = 0mV ±200 µV VCSP–CSN = 32mV ±2.5 % NTC/NTCBIAS = 50%, 75% ±2 % NTC/NTCBIAS = 5% ±3.5 % 4015fb For more information www.linear.com/LTC4015 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Data Sheet Conventions Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram I2C Timing Diagram Operation Applications Information Register Description DETAILED Register Descriptions Typical Applications Package Description Revision History Typical Application Related Parts
