Datasheet LTC4001-1 (Analog Devices) - 3
Описание2A Synchronous Buck Li-Ion Charger
Страниц / Страница20 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 236 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
10 предложений от 9 поставщиков
Микросхема Чип управления батареи, Battery Charger Li-Ion/Li-Pol 2000mA 4.1V 16Pin QFN EP T/R
LTC4001EUF-1#TRPBF
212 ₽
LTC4001EUF-1#TRPBF
250 ₽
727GS
LTC4001EUF-1#TRPBF
LTC4001EUF-1#TRPBF
LTC4001-1
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 5V, VEN = 0V, RPROG = 549Ω, RIDET = 549Ω, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
fOSC Oscillator Frequency 1.3 1.5 1.7 MHz D Maximum Duty Factor 100 % RPFET RDS(ON) of P-Channel MOSFET Measured from PVIN to SW 127 mΩ RNFET RDS(ON) of N-Channel MOSFET Measured from SW to PGND 121 mΩ tTIMER Timer Accuracy CTIMER = 0.22μF ±10 % VEN Enable Input Threshold Voltage VEN Rising 0.6 0.8 1 V ΔVEN Enable Input Hysteresis 100 mV VPROG PROG Pin Voltage RPROG = 549Ω 1.213 V VIDET IDET Pin Voltage RIDET = 549Ω 1.213 V IIDET IDET Threshold RIDET = 549Ω 150 200 250 mA ICHRG CHRG Pin Weak Pull-Down VCHRG = 1V 15 30 50 μA Current VCHRG CHRG Pin Output Low Voltage ICHRG = 5mA 0.2 0.4 V VOL FAULT Pin Output Low Voltage 1mA Load 0.4 V VOH FAULT Pin Output High Voltage 1mA Load 4.6 V VRECHRG Recharge Battery Threshold VFLOAT – VRECHRG VBAT Falling 50 100 135 mV Voltage tRB Recharge Filter Time Constant 4 ms tRECHRG Recharge Time Percent of Total Charge Time 50 % tTRIKL Low-Battery Trickle Charge Time Percent of Total Charge Time, VBAT < 2.8V, 25 % Measured Using BATSENS and GNDSENS Pins ISS Soft-Start Ramp Current VBAT < VFLOAT – 100mV, VBAT Across BATSENS 6 12.8 16 μA and GNDSENS Pins VCOLD NTC Pin Cold Temperature Fault From NTC to GNDSENS Pin Threshold Rising Threshold 0.74 VINSENSE V Falling Threshold 0.72 VINSENSE V VHOT NTC Pin Hot Temperature Fault From NTC to GNDSENS Pin Threshold Falling Threshold 0.29 VINSENSE V Rising Threshold 0.30 VINSENSE V VDIS NTC Disable Threshold (Falling) From NTC to GNDSENS Pin 0.015 • 0.02 • 0.025 • V VINSENSE VINSENSE VINSENSE ΔVDIS NTC Disable Hysteresis From NTC to GNDSENS Pin 0.01 • V VINSENSE
Note 1:
Note 4:
TJ is calculated from the ambient temperature TA and power dis- may cause permanent damage to the device. Exposure to any Absolute sipation PD according to the following formula: Maximum Rating condition for extended periods may affect device TJ = TA + (PD • 37°C/W) reliability and lifetime.
Note 5:
This IC includes overtemperature protection that is intended to
Note 2:
Operation with current limited wall adapters is allowed down to the protect the device during momentary overload. Junction temperature will undervoltage lockout threshold. exceed 125°C when overtemperature protection is active. Continuous
Note 3:
The LTC4001E-1 is guaranteed to meet performance specifi ca- operation above the specifi ed maximum operating junction temperature tions from 0°C to 85°C. Specifi cations over the – 40°C to 85°C operating my impair device reliability. temperature range are assured by design, characterization and correlation with statistical process controls. 40011fa 3
