Datasheet LTC4010 (Analog Devices) - 9
ОписаниеHigh Efficiency Standalone Nickel Battery Charger
Страниц / Страница24 / 9 — (Refer to Figure 1). Figure 1. LTC4010 State Diagram
Формат / Размер файлаPDF / 292 Кб
(Refer to Figure 1) Figure 1 LTC4010 State Diagram
44 предложений от 22 поставщиков
Микросхема Чип управления батареи, Battery Charger NiCD/NiMH 16Pin TSSOP EP T/R
Контест
LTC4010CFE
1 152 ₽
LTC4010CFE#PBF
от 1 721 ₽
TradeElectronics
LTC4010CFE#TRPBF
ТаймЧипс
LTC4010CFE
LTC4010 block DiagraM FAULT READY 1 16 CHRG 2 UVLO AND VCC 4 GND SHUTDOWN 15 CHEM 3 THERMISTOR TGATE 14 INTERFACE BGATE 12 CHARGER V PGND TEMP 5 STATE 13 A/D CONTROL PWM VCELL SENSE 6 CONVERTER LOGIC 9 BAT 10 BATTERY DETECTOR VOLTAGE INTVDD 11 REGULATOR TIMER CHARGE 8 TIMER INTERNAL VCDIV VOLTAGE 7 REGULATOR 4010 BD VOLTAGE REFERENCE operaTion
(Refer to Figure 1)
NO DC ADAPTER SHUTDOWN DC ADAPTER PRESENT NO BATTERY CHARGE OR QUALIFICATION VCC < 4.25V VCELL > 350mV, ADEQUATE VCC, CHARGER ENABLED AND TEMPERATURE OK (OPTIONAL) VCELL < 900mV CHECK PRECHARGE** BATTERY (C/5 FOR tMAX/12) > 900mV VCELL > 900mV VCELL VCELL < 900mV NiMH VCELL < 1.22V AT tMAX*/12 TOP-OFF ∆T/∆t FAST CHARGE** OR TIME = tMAX CHARGE** (1C) FAULT (C/10) NiCd OR NiMH – ∆V VCELL > 1.95V VCELL < 1.325V OR PWM FAULTS tMAX/3 AUTOMATIC RECHARGE 4010 F01 *tMAX IS PROGRAMMED MAXIMUM FAST CHARGE DURATION **OPTIONAL TEMPERATURE LIMITS APPLY
4010fb Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Related Parts
