Линейка продуктов KEEN SIDE
Datasheet ADE9000 (Analog Devices) - 4
ОписаниеHigh Performance, Multiphase Energy, and Power Quality Measurement IC
Страниц / Страница72 / 4 — ADE9000. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. …
ВерсияA
ADE9000. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
ADE9000 Data Sheet SPECIFICATIONS Table 1 Parameter Min Typ Max Unit Test Conditions/Comments
25 предложений от 13 поставщиков
Интегральные микросхемы Микросхемы сбора данных - Аналоговые препроцессоры
727GS
ADE9000ACPZ-RL
от 197 ₽
Зенер
Россия и страны ТС
ADE9000ACPZ-RL
от 864 ₽
ADE9000ACPZ
1 145 ₽
Hi-Tech Circuit Group
ADE9000ACPZ-RL
VDD = 2.97 V to 3.63 V, GND = AGND = DGND = 0 V, on-chip reference, CLKIN = 24.576 MHz crystal (XTAL), TMIN to TMAX = −40°C to +85°C, TA = 25°C (typical), unless otherwise noted.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
ACCURACY (MEASUREMENT ERROR PER PHASE) Total Active Energy 0.1 % Over a dynamic range of 5000 to 1, 10 sec accumulation 0.2 % Over a dynamic range of 10,000 to 1, 20 sec accumulation 0.1 % Over a dynamic range of 1000 to 1, 2 sec accumulation, PGA = 4, integrator on, high-pass filter (HPF) corner = 4.98 Hz 0.2 % Over a dynamic range of 5000 to 1, 10 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz Total Reactive Energy 0.1 % Over a dynamic range of 5000 to 1, 10 sec accumulation 0.2 % Over a dynamic range of 10,000 to 1, 20 sec accumulation 0.1 % Over a dynamic range of 1000 to 1, 2 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz 0.2 % Over a dynamic range of 5000 to 1, 10 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz Total Apparent Energy 0.1 % Over a dynamic range of 1000 to 1, 2 sec accumulation 0.5 % Over a dynamic range of 5000 to 1, 10 sec accumulation 0.1 % Over a dynamic range of 500 to 1, 1 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz 0.5 % Over a dynamic range of 1000 to 1, 2 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz Fundamental Active Energy 0.1 % Over a dynamic range of 5000 to 1, 2 sec accumulation 0.2 % Over a dynamic range of 10,000 to 1, 10 sec accumulation 0.1 % Over a dynamic range of 1000 to 1, 2 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz 0.2 % Over a dynamic range of 5000 to 1, 10 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz Fundamental Reactive Energy 0.1 % Over a dynamic range of 5000 to 1, 2 sec accumulation 0.2 % Over a dynamic range of 10,000 to 1, 10 sec accumulation 0.1 % Over a dynamic range of 1000 to 1, 2 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz 0.2 % Over a dynamic range of 5000 to 1, 10 sec accumulation, PGA = 4, integrator on, HPF corner = 4.98 Hz Rev. A | Page 4 of 72 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION REVISION HISTORY TYPICAL APPLICATIONS CIRCUIT SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ENERGY LINEARITY OVER SUPPLY AND TEMPERATURE ENERGY ERROR OVER FREQUENCY AND POWER FACTOR ENERGY LINEARITY REPEATABILITY RMS LINEARITY OVER TEMPERATURE AND RMS ERROR OVER FREQUENCY ENERGY AND RMS LINEARITY WITH INTEGRATOR ON ENERGY AND RMS ERROR OVER FREQUENCY WITH INTEGRATOR ON SIGNAL-TO-NOISE RATIO PERFORMANCE TEST CIRCUIT TERMINOLOGY THEORY OF OPERATION MEASUREMENTS Current Channel ADC_REDIRECT Multiplexer Current Channel Gain, xIGAIN IB Calculation Using ICONSEL High-Pass Filter Digital Integrator Phase Compensation Multipoint Phase and Gain Calibration Voltage Channel RMS and Power Measurements Total and Fundamental RMS Total and Fundamental Active Power Total and Fundamental Reactive Power Total and Fundamental Apparent Power No Load Detection, Energy Accumulation, and Power Accumulation Features No Load Detection Feature Energy Accumulation Power Accumulation Digital to Frequency Conversion—CFx Output Energy and Phase Selection Configuring the CFx Pulse Width CFx Pulse Sign Clearing the CFx Accumulator POWER QUALITY MEASUREMENTS Zero-Crossing Detection CF3/ZX Zero-Crossing Timeout Line Period Calculation Angle Measurement Phase Sequence Error Detection Fast RMS½ Measurement 10 Cycle RMS/12 Cycle RMS Dip and Swell Indication Overcurrent Indication Peak Detection Power Factor Total Harmonic Distortion (THD) Resampling 128 Points per Cycle Temperature WAVEFORM BUFFER INTERRUPTS/EVENTS ACCESSING ON-CHIP DATA SPI PROTOCOL OVERVIEW ADDITIONAL COMMUNICATION VERIFICATION REGISTERS CRC OF CONFIGURATION REGISTERS CONFIGURATION LOCK REGISTER MAP REGISTER DETAILS OUTLINE DIMENSIONS ORDERING GUIDE
