Datasheet ADE7880 (Analog Devices) - 8
ОписаниеPolyphase Multifunction Energy Metering IC with Harmonic Monitoring
Страниц / Страница107 / 8 — ADE7880. Data Sheet. Parameter1, 2. Min. Typ. Max. Unit. Test …
ВерсияC
Формат / Размер файлаPDF / 1.9 Мб
ADE7880. Data Sheet. Parameter1, 2. Min. Typ. Max. Unit. Test Conditions/Comments. TIMING CHARACTERISTICS
ADE7880 Data Sheet Parameter1, 2 Min Typ Max Unit Test Conditions/Comments TIMING CHARACTERISTICS
46 предложений от 21 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Измерение энергии
Элитан
ADE7880ACPZ
655 ₽
ADE7880ACPZ
от 1 854 ₽
Эиком
ADE7880ACPZ
от 2 187 ₽
ADE7880ACPZ-RL
2 207 ₽
link to page 14 link to page 20 link to page 12 link to page 12
PSM1 and PSM2 Modes VDD Pin 2.4 3.7 V IDD PSM1 Mode 5.3 5.8 mA PSM2 Mode 0.2 0.27 mA PSM3 Mode For specified performance VDD Pin 2.4 3.7 V IDD in PSM3 Mode 1.8 6 μA 1 See the Typical Performance Characteristics section. 2 See the Terminology section for a definition of the parameters. 2800 3   means the whole number of the division.  fL 
VDD = 3.3 V ± 10%, AGND = DGND = 0 V, on-chip reference, CLKIN = 16.384 MHz, TMIN to TMAX = −40°C to +85°C. Note that dual function pin names are referenced by the relevant function only within the timing tables and diagrams (see the Pin Configuration and Function Descriptions section for full pin mnemonics and descriptions).
Table 2. I2C-Compatible Interface Timing Parameter Standard Mode Fast Mode Parameter Symbol Min Max Min Max Unit
SCL Clock Frequency fSCL 0 100 0 400 kHz Hold Time (Repeated) Start Condition tHD;STA 4.0 0.6 μs Low Period of SCL Clock tLOW 4.7 1.3 μs High Period of SCL Clock tHIGH 4.0 0.6 μs Set-Up Time for Repeated Start Condition tSU;STA 4.7 0.6 μs Data Hold Time tHD;DAT 0.1 3.45 0.1 0.9 μs Data Setup Time tSU;DAT 250 100 ns Rise Time of Both SDA and SCL Signals tR 1000 20 300 ns Fall Time of Both SDA and SCL Signals tF 300 20 300 ns Setup Time for Stop Condition tSU;STO 4.0 0.6 μs Bus Free Time Between a Stop and Start Condition tBUF 4.7 1.3 μs Pulse Width of Suppressed Spikes tSP N/A1 50 ns 1 N/A means not applicable.
SDA t t t BUF F SU;DAT tHD;STA t t SP F tF tF tLOW SCL tHD;STA t t HD;DAT t t SU;STA SU;STO HIGH
02 0
START REPEATED START STOP START
3-
CONDITION CONDITION CONDITION CONDITION
19 10 Figure 2. I2C-Compatible Interface Timing Rev. C | Page 8 of 107 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT TERMINOLOGY POWER MANAGEMENT PSM0—NORMAL POWER MODE (ALL PARTS) PSM1—REDUCED POWER MODE PSM2—LOW POWER MODE PSM3—SLEEP MODE (ALL PARTS) POWER-UP PROCEDURE HARDWARE RESET SOFTWARE RESET FUNCTIONALITY THEORY OF OPERATION ANALOG INPUTS ANALOG-TO-DIGITAL CONVERSION Antialiasing Filter ADC Transfer Function CURRENT CHANNEL ADC Current Waveform Gain Registers Current Channel HPF Current Channel Sampling di/dt CURRENT SENSOR AND DIGITAL INTEGRATOR VOLTAGE CHANNEL ADC Voltage Waveform Gain Registers Voltage Channel HPF Voltage Channel Sampling CHANGING PHASE VOLTAGE DATA PATH POWER QUALITY MEASUREMENTS Zero-Crossing Detection Zero-Crossing Timeout Phase Sequence Detection Time Interval Between Phases Period Measurement Phase Voltage Sag Detection Sag Level Set Peak Detection Overvoltage and Overcurrent Detection Overvoltage and Overcurrent Level Set Neutral Current Mismatch PHASE COMPENSATION REFERENCE CIRCUIT DIGITAL SIGNAL PROCESSOR ROOT MEAN SQUARE MEASUREMENT Current RMS Calculation Current RMS Offset Compensation Current Mean Absolute Value Calculation Current MAV Gain and Offset Compensation Voltage Channel RMS Calculation Voltage RMS Offset Compensation Voltage RMS in 3-Phase, 3-Wire Delta Configurations ACTIVE POWER CALCULATION Total Active Power Calculation Fundamental Active Power Calculation Managing Change in Fundamental Line Frequency Active Power Gain Calibration Active Power Offset Calibration Sign of Active Power Calculation Active Energy Calculation Integration Time Under Steady Load Active Energy Accumulation Modes Line Cycle Active Energy Accumulation Mode FUNDAMENTAL REACTIVE POWER CALCULATION Fundamental Reactive Power Gain Calibration Fundamental Reactive Power Offset Calibration Sign of Fundamental Reactive Power Calculation Fundamental Reactive Energy Calculation Integration Time Under Steady Load Fundamental Reactive Energy Accumulation Modes Line Cycle Reactive Energy Accumulation Mode APPARENT POWER CALCULATION Apparent Power Gain Calibration Apparent Power Offset Calibration Apparent Power Calculation Using VNOM Apparent Energy Calculation Integration Time Under Steady Load Apparent Energy Accumulation Modes Line Cycle Apparent Energy Accumulation Mode POWER FACTOR CALCULATION HARMONICS CALCULATIONS Harmonics Calcuations Theory Configuring the Harmonic Calculations Harmonic Calculations When a Phase is Monitored Harmonic Calculations When the Neutral is Monitored Configuring Harmonic Calculations Update Rate Recommended Approach to Managing Harmonic Calculations WAVEFORM SAMPLING MODE ENERGY-TO-FREQUENCY CONVERSION Synchronizing Energy Registers with CFx Outputs Energy Registers and CF Outputs for Various Accumulation Modes Sign of Sum of Phase Powers in the CFx Data Path NO LOAD CONDITION No Load Detection Based On Total Active Power and Apparent Power No Load Detection Based on Fundamental Active and Reactive Powers No Load Detection Based on Apparent Power CHECKSUM REGISTER INTERRUPTS Using the Interrupts with an MCU SERIAL INTERFACES Serial Interface Choice Communication Verification I2C-Compatible Interface I2C Write Operation I2C Read Operation I2C Read Operation of Harmonic Calculations Registers SPI-Compatible Interface SPI Read Operation SPI Read Operation of Harmonic Calculations Registers SPI Write Operation HSDC Interface ADE7880 QUICK SETUP AS ENERGY METER LAYOUT GUIDELINES CRYSTAL CIRCUIT ADE7880 EVALUATION BOARD DIE VERSION SILICON ANOMALY ADE7880 FUNCTIONALITY ISSUES FUNCTIONALITY ISSUES SECTION 1. ADE7880 FUNCTIONALITY ISSUES REGISTERS LIST OUTLINE DIMENSIONS ORDERING GUIDE
