Datasheet ADE7768 (Analog Devices) - 7
ОписаниеEnergy Metering IC with Integrated Oscillator and Positive Power Accumulation
Страниц / Страница20 / 7 — ADE7768. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VDD 1. 16 F1. V2P. …
ВерсияA
Формат / Размер файлаPDF / 408 Кб
ADE7768. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VDD 1. 16 F1. V2P. 15 F2. V2N. 14 CF. V1N. 13 DGND. TOP VIEW. V1P. (Not to Scale) 12 REVP
ADE7768 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD 1 16 F1 V2P 15 F2 V2N 14 CF V1N 13 DGND TOP VIEW V1P (Not to Scale) 12 REVP
17 предложений от 17 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Измерение энергии
ADE7768ARZ
23 ₽
ТаймЧипс
ADE7768ARZ-RL
Рутоника
ADE7768ARZ-RL
ADE7768ARZ-RL
link to page 15
ADE7768 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD 1 16 F1 V2P 2 15 F2 V2N 3 14 CF ADE7768 V1N 4 13 DGND TOP VIEW V1P 5 (Not to Scale) 12 REVP AGND 6 11 RCLKIN REFIN/OUT 7 10 S0 SCF 8 9 S1
05331-003 Figure 3. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 VDD Power Supply. This pin provides the supply voltage for the circuitry in the ADE7768. The supply voltage should be maintained at 5 V ± 5% for specified operation. This pin should be decoupled with a 10 μF capacitor in parallel with a 100 nF ceramic capacitor. 2, 3 V2P, V2N Analog Inputs for Channel V2 (Voltage Channel). These inputs provide a fully differential input pair. The maximum differential input voltage is ±165 mV for specified operation. Both inputs have internal ESD protection circuitry; an overvoltage of ±6 V can be sustained on these inputs without risk of permanent damage. 4, 5 V1N, V1P Analog Inputs for Channel V1 (Current Channel). These inputs are fully differential voltage inputs with a maximum signal level of ±30 mV with respect to the V1N pin for specified operation. Both inputs have internal ESD protection circuitry and, in addition, an overvoltage of ±6 V can be sustained on these inputs without risk of permanent damage. 6 AGND This pin provides the ground reference for the analog circuitry in the ADE7768, that is, the ADCs and reference. This pin should be tied to the analog ground plane of the PCB. The analog ground plane is the ground reference for all analog circuitry, such as antialiasing filters, current and voltage sensors, and so forth. For accurate noise suppression, the analog ground plane should be connected to the digital ground plane at only one point. A star ground configuration helps to keep noisy digital currents away from the analog circuits. 7 REFIN/OUT This pin provides access to the on-chip voltage reference. The on-chip reference has a nominal value of 2.45 V and a typical temperature coefficient of 20 ppm/°C. An external reference source may also be connected at this pin. In either case, this pin should be decoupled to AGND with a 1 μF tantalum capacitor and a 100 nF ceramic capacitor. The internal reference cannot be used to drive an external load. 8 SCF Select Calibration Frequency. This logic input is used to select the frequency on the calibration output CF. See Table 7. 9, 10 S1, S0 These logic inputs are used to select one of four possible frequencies for the digital-to-frequency conversion. With this logic input, designers have greater flexibility when designing an energy meter. See the Selecting a Frequency for an Energy Meter Application section. 11 RCLKIN To enable the internal oscillator as a clock source to the chip, a precise low temperature drift resistor at a nominal value of 6.2 kΩ must be connected from this pin to DGND. 12 REVP This logic output goes high when negative power is detected, that is, when the phase angle between the voltage and current signals is greater than 90°. This output is not latched and is reset when positive power is once again detected. The output goes high or low at the same time that a pulse is issued on CF. 13 DGND This pin provides the ground reference for the digital circuitry in the ADE7768, that is, the multiplier, filters, and digital-to-frequency converter. This pin should be tied to the digital ground plane of the PCB. The digital ground plane is the ground reference for all digital circuitry, such as counters (mechanical and digital), MCUs, and indicator LEDs. For accurate noise suppression, the analog ground plane should be connected to the digital ground plane at one point only—a star ground. 14 CF Calibration Frequency Logic Output. The CF logic output provides instantaneous, positive-only real power information. This output is intended for calibration purposes. See the SCF pin description. 15, 16 F2, F1 Low Frequency Logic Outputs. F1 and F2 supply average positive-only real power information. The logic outputs can be used to directly drive electromechanical counters and 2-phase stepper motors. See the Transfer Function section. Rev. A | Page 7 of 20 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TERMINOLOGY PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION THEORY OF OPERATION Power Factor Considerations Nonsinusoidal Voltage and Current ANALOG INPUTS Channel V1 (Current Channel) Channel V2 (Voltage Channel) Typical Connection Diagrams POWER SUPPLY MONITOR HPF and Offset Effects Digital-to-Frequency Conversion Connecting to a Microcontroller for Energy Measurement Power Measurement Considerations INTERNAL OSCILLATOR (OSC) TRANSFER FUNCTION Frequency Outputs F1 and F2 Example Frequency Output CF SELECTING A FREQUENCY FOR AN ENERGY METER APPLICATION Frequency Outputs NO-LOAD THRESHOLD NEGATIVE POWER INFORMATION EVALUATION BOARD AND REFERENCE DESIGN BOARD OUTLINE DIMENSIONS ORDERING GUIDE
