Datasheet LT1389 (Analog Devices) - 9
ОписаниеNanopower Precision Shunt Voltage Reference
Страниц / Страница12 / 9 — APPLICATIO S I FOR ATIO. Figure 1. Adjustable Output Voltage Reference. …
Формат / Размер файлаPDF / 219 Кб
APPLICATIO S I FOR ATIO. Figure 1. Adjustable Output Voltage Reference. Figure 2. Guard Ring to Reduce Board Leakage
APPLICATIO S I FOR ATIO Figure 1 Adjustable Output Voltage Reference Figure 2 Guard Ring to Reduce Board Leakage
15 предложений от 12 поставщиков
Опорный чип напряжения, V-Ref Precision 5V 10mA 8Pin SOIC N T/R
727GS
LT1389BCS8-5#TRPBF
от 500 ₽
LT1389BCS8-5#TRPBF
LT1389BCS8-5#TRPBF
Hi-Tech Circuit Group
LT1389BCS8-5#TRPBF
LT1389
U U W U APPLICATIO S I FOR ATIO
The reverse characteristics of the LT1389 resembles a Board leakage is a concern for a nanopower precision simple resistor Zener diode parallel connection. This well shunt voltage reference. The LT1389 requires attention to behaved characteristic is important to the proper opera- detail in board layout in order to maximize its perfor- tion of circuits like Figure 1. The adjustable output voltage mance. 1.5GΩ of leakage between a DNC pin and a 5V reference depends upon positive feedback from the supply will conduct 2.5nA which induces a 0.2% error in LT1495’s output to start-up and regulate the bias current VOUT. Board leakage can be minimized by encircling the for the LT1389. The LT1389 has no negative resistance DNC pins with a guard ring operated at a potential of VOUT. regions that can interfere with the proper start-up of the By tying the guard ring to VOUT as shown in Figure 2, buffered reference. leakage paths are eliminated. VIN ≥ 10.5V V R OUT – 1.25V B = 0.8µA + V LT1495 OUT LT1389-1.25 1.5V TO 10V – R1 249k TO 8.66M R2 1.24M 1389 F01
BOARD METAL TRACE DNC 1 8 DNC DNC 2 7 DNC LT1389 DNC 3 6 VOUT GND 4 5 GND 1389 F02
9
