Datasheet LT6003, LT6004, LT6005 (Analog Devices) - 8
| Производитель | Analog Devices |
| Описание | 1.6V, 1µA Precision Rail-to-Rail Input and Output Op Amps |
| Страниц / Страница | 20 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. VOS Distribution. TC VOS … |
| Формат / Размер файла | PDF / 1.2 Мб |
TYPICAL PERFORMANCE CHARACTERISTICS. VOS Distribution. TC VOS Distribution. Supply Current vs Supply Voltage
10 предложений от 10 поставщиков IC OPAMP GP 4 CIRCUIT 16DFN. General Purpose Amplifier 4 Circuit Rail-to-Rail 16-DFN-EP (5x3). Linear - Amplifiers - Instrumentation, OP Amps,... |
| LT6005IDHC#TRPBF Analog Devices | 153 ₽ | |
| LT6005IDHC#TRPBF Analog Devices | 192 ₽ | |
| LT6005IDHC#TRPBF Linear Technology | по запросу | |
| LT6005IDHC#TRPBF
| по запросу | |
LT6003/LT6004/LT6005
TYPICAL PERFORMANCE CHARACTERISTICS VOS Distribution TC VOS Distribution Supply Current vs Supply Voltage
35 20 5.0 VS = 5V, 0V VS = 5V, 0V VCM = 0.5V VCM = 2.5V 18 VCM = 2.5V 4.5 30 MS8 PACKAGE MS8, GN16, TA = 125°C 16 1377 AMPLIFIERS SOT23 PACKAGES 4.0 25 14 –40°C TO 85°C 3.5 12 3.0 TA = 85°C 20 10 2.5 T 15 A = 25°C 8 2.0 6 1.5 PERCENT OF UNITS (%) 10 PERCENT OF UNITS (%) TA = –55°C Y CURRENT PER AMPLIFIER (µA) 4 1.0 5 2 SUPPL 0.5 0 0 0 –600 –400 –200 0 200 400 600 –5 –4 –3 –2 –1 0 1 2 3 4 5 0 2 4 6 8 10 12 14 16 INPUT OFFSET VOLTAGE (µV) DISTRIBUTION (µV/°C) SUPPLY VOLTAGE (V) 600345 G01 600345 G02 600345 G03
Change in Input Offset Voltage Input Offset Voltage Input Offset Voltage vs Total Supply Voltage vs Total Supply Voltage vs Input Common Mode Voltage
250 300 100 VCM = 0.5V TYPICAL PART 50 200 200 V) TA = 25°C V) 0 V) 150 100 TA = –55°C TAGE (µ TA = 25°C TAGE (µ –50 100 0 TA = –55°C TA = –55°C –100 50 TA = 25°C –100 –150 T T A = 125°C A = 125°C 0 OFFSET VOTLAGE (µ –200 –200 INPUT OFFSET VOL CHANGE IN OFFSET VOL –50 TA = 125°C –300 –250 VS = 5V, 0V TYPICAL PART –100 –400 –300 1 1.5 2.0 2.5 3.0 0 2 4 6 8 10 12 14 16 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 TOTAL SUPPLY VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) 60012 G05 600345 G06 600345 G04
Input Bias Current Output Saturation Voltage Output Saturation Voltage vs Common Mode Voltage vs Load Current (Output High) vs Load Current (Output Low)
3.0 1.0 1.0 VS = 5V, 0V V V S = 5V, 0V S = 5V, 0V 2.5 INPUT OVERDRIVE = 30mV INPUT OVERDRIVE = 30mV TA = 125°C 2.0 TAGE (V) TAGE (V) T 1.5 A = 125°C 0.1 1.0 TION VOL T TION VOL A = 125°C T 0.1 A = –55°C 0.1 TA = 85°C TURA TURA 0 TA = 25°C 0.01 –0.1 TA = –55°C TA = 25°C T INPUT BIAS CURRENT (nA) A = –55°C –0.2 TA = 25°C –0.3 OUTPUT HIGH SA OUTPUT LOW SA –0.4 0.01 0.001 0 1 2 3 4 5 0.00001 0.001 0.1 10 0.00001 0.001 0.1 10 COMMON MODE VOLTAGE (V) SOURCING LOAD CURRENT (mA) SINKING LOAD CURRENT (mA) 600345 G09 600345 G07 600345 G08 600345fd 8
