Datasheet LTC6078, LTC6079 (Analog Devices) - 5
ОписаниеMicropower Precision, Dual/Quad CMOS Rail-to-Rail Input/Output Amplifiers
Страниц / Страница20 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 344 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
33 предложений от 14 поставщиков
LTC6078IDD#TRPBF
от 78 ₽
LTC6078IDD#TRPBF
197 ₽
Зенер
Россия и страны ТС
LTC6078IDD#TRPBF
от 213 ₽
LTC6078IDD#TRPBF
LTC6078/LTC6079
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Test conditions are V+ = 5V, V– = 0V, VCM = 0.5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS C, I SUFFIXES H SUFFIX UNITS MIN TYP MAX MIN TYP MAX
CMRR Common Mode Rejection All Packages VCM = 0V to 5V 91 105 91 105 dB Ratio LTC6078AMS8 VCM = 0V to 5V ● 90 105 90 105 dB LTC6078AMS8 VCM = 0V to 3.7V ● 94 105 94 105 dB LTC6078MS8 VCM = 0V to 5V ● 88 100 88 100 dB LTC6078MS8 VCM = 0V to 3.7V ● 90 105 90 105 dB LTC6079GN VCM = 0V to 5V ● 86 100 86 100 dB LTC6079GN VCM = 0V to 3.7V ● 90 105 90 105 dB LTC6078DD, LTC6079DHC VCM = 0V to 5V ● 86 100 dB LTC6078DD, LTC6079DHC VCM = 0V to 3.7V ● 90 105 dB PSRR Power Supply Rejection Ratio VS = 2.7V to 5.5V 100 120 120 dB ● 97 97 dB VOUT Output Voltage, High No Load 2 2 mV (Referred to V+) ISOURCE = 0.5mA ● 50 20 55 20 mV ISOURCE = 5mA ● 500 200 550 200 mV Output Voltage, Low No Load 1 1 mV (Referred to V–) ISINK = 0.5mA ● 15 40 15 45 mV ISINK = 5mA ● 150 400 150 450 mV AVOL Large-Signal Voltage Gain RLOAD = 10k, 0.5V ≤ VOUT ≤ 4.5V ● 115 130 110 125 dB ISC Output Short-Circuit Current Source ● 14 25 12 25 mA Sink ● 14 25 12 25 mA SR Slew Rate AV = 1 0.05 0.05 V/μs GBW Gain-Bandwidth Product RL = 100k 420 750 420 750 kHz (fTEST = 10kHz) ● 360 320 kHz Φ0 Phase Margin RL = 10k, CL = 200pF 66 66 Deg tS Settling Time 0.1% AV = 1, 1V Step 24 24 μs IS Supply Current No Load 55 74 55 74 μA (per Amplifi er) ● 82 84 μA Shutdown Current Shutdown, VSHDN ≤ 1.2V, LTC6078DD ● 1.5 5 1.5 5 μA (per Amplifi er) VS Supply Voltage Range Guaranteed by the PSRR Test ● 2.7 5.5 2.7 5.5 V Channel Separation fs = 10kHz, RL = 10k –110 –110 dB Shutdown Logic SHDN High, LTC6078DD ● 3.5 3.5 V SHDN Low, LTC6078DD ● 1.2 1.2 V tON Turn on Time VSHDN = 1.2V to 3.5V, LTC6078DD 50 50 µs tOFF Turn off Time VSHDN = 1.2V to 3.5V, LTC6078DD 2 2 µs Leakage of SHDN Pin VSHDN = 0V, LTC6078DD 0.6 μA
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings performance from 0°C to 70°C. The LTC6078C/LTC6079C are designed, may cause permanent damage to the device. Exposure to any Absolute characterized and expected to meet specifi ed performance from –40°C Maximum Rating condition for extended periods may affect device to 85°C but are not tested or QA sampled at these temperatures. The reliability and lifetime. LTC6078I/LTC6079I are guaranteed to meet specifi ed performance from
Note 2:
A heat sink may be required to keep the junction temperature –40°C to 85°C. The LTC6078H/LTC6079H are guaranteed to meet specifi ed below the absolute maximum. This depends on the power supply voltage performance from –40°C to 125°C. and how many amplifi ers are shorted.
Note 5:
VOS and VOS drift are 100% tested at 25°C and 125°C.
Note 3:
The LTC6078C/LTC6079C and LTC6078I/LTC6079I are guaranteed
Note 6:
IB and IOS are guaranteed by the VS = 5V test. functional over the operating temperature range of –40°C to 85°C. The
Note 7:
VOS drift is guaranteed by the VS = 3V test. LTC6078H/LTC6079H are guaranteed functional over the operating
Note 8:
Current noise is calculated from in = √2qIB, where q = 1.6 • 10–19 temperature range of –40°C to 125°C. coulomb.
Note 4:
The LTC6078C/LTC6079C are guaranteed to meet specifi ed 60789fa 5
