Datasheet LT6013, LT6014 (Analog Devices) - 6
ОписаниеSingle/Dual 145µA, 9.5nV/√Hz, AV ≥5, Rail-to-Rail Output Precision Op Amps
Страниц / Страница16 / 6 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
Формат / Размер файлаPDF / 346 Кб
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
IC OPAMP GP 2 CIRCUIT 8DFN. General Purpose Amplifier 2 Circuit Rail-to-Rail 8-DFN (3x3). Linear - Amplifiers - Instrumentation, OP Amps,...
LT6014ACDD#TRPBF
197 ₽
Рутоника
LT6014ACDD#TRPBF
250 ₽
LT6014ACDD TRPBF
727GS
LT6014ACDD#TRPBF
LT6013/LT6014
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VS =
15V, VCM = 0V, RL to 0V, unless otherwise specified. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
∆VOS/∆T Input Offset Voltage Drift (Note 6) S8 Packages ● 0.2 0.8 µV/°C DD Packages ● 0.2 1.2 µV/°C IOS Input Offset Current (Note 8) LT6013AS8, LT6013ADD 100 250 pA TA = 0°C to 70°C ● 500 pA TA = –40°C to 85°C ● 600 pA LT6014AS8, LT6014ADD 100 500 pA TA = 0°C to 70°C ● 600 pA TA = –40°C to 85°C ● 700 pA LT6013/LT6014 (Standard grades) 150 800 pA TA = 0°C to 70°C ● 1000 pA TA = –40°C to 85°C ● 1200 pA IB Input Bias Current (Note 8) LT6013AS8, LT6013ADD 100 ±250 pA TA = 0°C to 70°C ● ±500 pA TA = –40°C to 85°C ● ±600 pA LT6013S8, LT6013DD, LT6014AS8, LT6014ADD 100 ±400 pA TA = 0°C to 70°C ● ±600 pA TA = –40°C to 85°C ● ±800 pA LT6014S8, LT6014DD 150 ±800 pA TA = 0°C to 70°C ● ±1000 pA TA = –40°C to 85°C ● ±1200 pA en Input Noise Voltage Density f = 1kHz, LT6013/LT6014 9.5 nV/√Hz f = 1kHz, LT6013A/LT6014A 9.5 13 nV/√Hz Input Noise Voltage (Low Frequency) Bandwidth = 0.01Hz to 1Hz 200 nVP-P 50 nVRMS Bandwidth = 0.1Hz to 10Hz 200 nVP-P 40 nVRMS in Input Noise Current Density f = 1kHz 0.15 pA/√Hz Input Noise Current (Low Frequency) Bandwidth = 0.01Hz to 1Hz 7 pAP-P 1.3 pARMS Bandwidth = 0.1Hz to 10Hz 5 pAP-P 0.4 pARMS RIN Input Resistance Common Mode, VCM = ±13.5V 400 GΩ Differential 20 MΩ CIN Input Capacitance 4 pF VCM Input Voltage Range Guaranteed by CMRR ● ±13.5 ±14 V CMRR Common Mode Rejection Ratio VCM = –13.5V to 13.5V 115 135 dB ● 112 135 dB Minimum Supply Voltage Guaranteed by PSRR ● ±1.2 ±1.35 V PSRR Power Supply Rejection Ratio VS = ±1.35V to ±18V ● 112 135 dB AVOL Large-Signal Voltage Gain RL = 10k, VOUT = –13.5V to 13.5V 1000 2000 V/mV ● 600 V/mV RL = 5k, VOUT = –13.5V to 13.5V 500 1500 V/mV ● 300 V/mV Channel Separation VOUT = –13.5V to 13.5V, LT6014 ● 120 140 dB 60134fb 6
