Datasheet LT6011, LT6012 (Analog Devices) - 4
ОписаниеDual/Quad 135µA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp
Страниц / Страница20 / 4 — elecTrical characTerisTics. The. denotes the specifications which apply …
Формат / Размер файлаPDF / 384 Кб
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
27 предложений от 19 поставщиков
LT6011ACDD#PBF
544 ₽
LT6011ACDD#PBF
1 503 ₽
SUV System
LT6011ACDD#TRPBF
LifeElectronics
LT6011ACDD#PBF
LT6011/LT6012
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 5V, 0V; VCM = 2.5V; RL to 0V; unless otherwise specified. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 8) LT6011AS8, LT6012AS 20 60 µV TA = 0°C to 70°C l 85 µV TA = –40°C to 85°C l 110 µV LT6011ADD, LT6012AGN 25 85 µV TA = 0°C to 70°C l 135 µV TA = –40°C to 85°C l 170 µV LT6011S8, LT6012S 25 75 µV TA = 0°C to 70°C l 100 µV TA = –40°C to 85°C l 125 µV LT6011DD, LT6012GN, LT6011MS8 30 125 µV TA = 0°C to 70°C l 175 µV TA = –40°C to 85°C l 210 µV ∆VOS/∆T Input Offset Voltage Drift (Note 6) LT6011AS8, LT6011S8, LT6012AS,LT6012S l 0.2 0.8 µV/°C LT6011ADD,LT6011DD, LT6012AGN, LT6012GN, LT6011MS8 l 0.2 1.2 µV/°C IOS Input Offset Current (Note 8) LT6011AS8, LT6011ADD, LT6012AS, LT6012AGN 20 300 pA TA = 0°C to 70°C l 450 pA TA = –40°C to 85°C l 600 pA LT6011S8, LT6011DD, LT6012S, LT6012GN, LT6011MS8 150 900 pA TA = 0°C to 70°C l 1200 pA TA = –40°C to 85°C l 1500 pA IB Input Bias Current (Note 8) LT6011AS8, LT6011ADD, LT6012AS, LT6012AGN 20 ±300 pA TA = 0°C to 70°C l ±450 pA TA = –40°C to 85°C l ±600 pA LT6011S8, LT6011DD, LT6012S, LT6012GN, LT6011MS8 150 ±900 pA TA = 0°C to 70°C l ±1200 pA TA = –40°C to 85°C l ±1500 pA Input Noise Voltage 0.1Hz to 10Hz 400 nVP-P en Input Noise Voltage Density f = 1kHz 14 nV/√Hz in Input Noise Current Density f = 1kHz, Unbalanced Source Resistance 0.1 pA/√Hz RIN Input Resistance Common Mode, VCM = 1V to 3.8V 10 120 GΩ Differential 20 MΩ CIN Input Capacitance 4 pF VCM Input Voltage Range (Positive) Guaranteed by CMRR l 3.8 4 V Input Voltage Range (Negative) Guaranteed by CMRR l 0.7 1 V CMRR Common Mode Rejection Ratio VCM = 1V to 3.8V l 107 135 dB Minimum Supply Voltage Guaranteed by PSRR l 2.4 2.7 V PSRR Power Supply Rejection Ratio VS = 2.7V to 36V, VCM = 1/2VS l 112 135 dB AVOL Large-Signal Voltage Gain RL = 10k, VOUT = 1V to 4V l 300 2000 V/mV RL = 2k, VOUT = 1V to 4V l 250 2000 V/mV Channel Separation VOUT = 1V to 4V l 110 140 dB 60112fc 4 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Package/Order Information Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Application Related Parts
