Datasheet LTC1992 (Analog Devices) - 5
ОписаниеLow Power, Fully Differential Input/Output Amplifier/Driver Family
Страниц / Страница42 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
Формат / Размер файлаPDF / 508 Кб
IC OPAMP DIFF 1 CIRCUIT 8MSOP. Differential Amplifier 1 Circuit Differential, Rail-to-Rail 8-MSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
LTC1992-1HMS8#TRPBF
196 ₽
LTC1992-1HMS8#TRPBF
360 ₽
LTC1992-1HMS8#TRPBF
396 ₽
LTC1992-1HMS8 TRPBF
LTC1992 Family
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. +VS = 5V, –VS = 0V, VINCM = VOUTCM = VOCM = 2.5V, unless otherwise noted. VOCM is the voltage on the VOCM pin. VOUTCM is defined as (+VOUT + –VOUT)/2. VINCM is defined as (+VIN + –VIN)/2. VINDIFF is defined as (+VIN – –VIN). VOUTDIFF is defined as (+VOUT – –VOUT). Typical values are at TA = 25°C. Specifications apply to the LTC1992-1 only. LTC1992-1CMS8 LTC1992-1ISM8 LTC1992-1HMS8 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
GDIFF Differential Gain 1 1 V/V Differential Gain Error l ±0.1 ±0.3 ±0.1 ±0.35 % Differential Gain Nonlinearity 50 50 ppm Differential Gain Temperature Coefficient l 3.5 3.5 ppm/°C en Input Referred Noise Voltage Density (Note 7) f = 1kHz 45 45 nV/√Hz RIN Input Resistance, Single-Ended +IN, –IN Pins l 22.5 30 37.5 22 30 38 kΩ VINCMR Input Signal Common Mode Range VS = 5V –0.1V to 4.9V –0.1V to 4.9V V CMRR Common Mode Rejection Ratio VINCM = –0.1V to 3.7V l 55 60 55 60 dB (Amplifier Input Referred) (Note 7) SR Slew Rate (Note 4) l 0.5 1.5 0.5 1.5 V/μs GBW Gain-Bandwidth Product fTEST = 180kHz 3 3 MHz
The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. +VS = 5V, –VS = 0V, VINCM = VOUTCM = VOCM = 2.5V, unless otherwise noted. VOCM is the voltage on the VOCM pin. VOUTCM is defined as (+VOUT + –VOUT)/2. VINCM is defined as (+VIN + –VIN)/2. VINDIFF is defined as (+VIN – –VIN). VOUTDIFF is defined as (+VOUT – –VOUT). Typical values are at TA = 25°C. Specifications apply to the LTC1992-2 only. LTC1992-2CMS8 LTC1992-2ISM8 LTC1992-2HMS8 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
GDIFF Differential Gain 2 2 V/V Differential Gain Error l ±0.1 ±0.3 ±0.1 ±0.35 % Differential Gain Nonlinearity 50 50 ppm Differential Gain Temperature Coefficient l 3.5 3.5 ppm/°C en Input Referred Noise Voltage Density (Note 7) f = 1kHz 45 45 nV/√Hz RIN Input Resistance, Single-Ended +IN, –IN Pins l 22.5 30 37.5 22 30 38 kΩ VINCMR Input Signal Common Mode Range VS = 5V –0.1V to 4.9V –0.1V to 4.9V V CMRR Common Mode Rejection Ratio VINCM = –0.1V to 3.7V l 55 60 55 60 dB (Amplifier Input Referred) (Note 7) SR Slew Rate (Note 4) l 0.7 2 0.7 2 V/μs GBW Gain-Bandwidth Product fTEST = 180kHz 4 4 MHz 1992fb 5
