Datasheet LT1462, LT1463 (Analog Devices) - 5
ОписаниеDual/Quad Micropower, 260µW C-Load Picoampere Bias Current JFET Input Op Amps
Страниц / Страница12 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias and Offset Current vs. …
Формат / Размер файлаPDF / 288 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias and Offset Current vs. Input Bias Current Over the. Common Mode Range vs
TYPICAL PERFORMANCE CHARACTERISTICS Input Bias and Offset Current vs Input Bias Current Over the Common Mode Range vs
27 предложений от 14 поставщиков
LT1462ACN8#PBF
от 1 159 ₽
Зенер
Россия и страны ТС
LT1462ACN8#PBF
от 1 182 ₽
Элитан
LT1462ACN8
1 208 ₽
LT1462ACN8#PBF
LT1462/LT1463
W U TYPICAL PERFORMANCE CHARACTERISTICS Input Bias and Offset Current vs Input Bias Current Over the Common Mode Range vs Temperature Common Mode Range Temperature
10000 20 16 VS = ±15V VS = ±15V 15 VCM = 0V TA = 25°C LT1462/LT1463 15 14 1000 LT1462A 13 10 12 100 BIAS CURRENT 5 –11 –12 10 INPUT BIAS CURRENT (pA) COMMON MODE RANGE (V) –13 OFFSET CURRENT 0 INPUT BIAS AND OFFSET CURRENT (pA) –14 VS = ±15V 1 –5 –15 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 –75 –50 –25 0 25 50 75 100 125 AMBIENT TEMPERATURE (°C) COMMON MODE INPUT VOLTAGE (V) TEMPERATURE (°C) LT1462 • TPC01 LT1462 • TPC02 LT1462 • TPC03
Supply Current vs Temperature Voltage Noise vs Frequency 0.1Hz to 10Hz Noise
60 1000 VS = ±15V µA) √Hz) TA = 25°C 50 40 µV/DIV) VS = ±15V 30 100 VS = ±5V NOISE VOLTAGE (2 20 1/f CORNER = 5Hz SUPPLY CURRENT PER AMPLIFIER ( RMS VOLTAGE NOISE DENSITY (nV/ 10 30 –75 –50 –25 0 25 50 75 100 125 0.1 1 10 100 1000 0 2 4 6 8 10 TEMPERATURE (°C) FREQUENCY (Hz) TIME (SEC) LT1462 • TPC04 LT1462 • TPC05 LT1462 • TPC06
Slew Rate, Gain Bandwidth Voltage Gain vs Temperature Product vs Temperature Channel Separation vs Frequency
1000 0.17 400 160 V V O = ±10V, VS = ±15V S = ±15V VS = ±15V 900 VO = ±2V, VS = ±5V TA = 25°C R SLEW RISE 800 L = 10k 140 RL = 10k GAIN BANDWIDTH (kHz) 0.15 300 700 VS = ±15V µs) 600 120 SLEW FALL 500 0.13 200 400 100 SLEW RATE (V/ GAIN BANDWIDTH 300 VOLTAGE GAIN (V/mV) VS = ±5V 0.11 100 CHANNEL SEPARATION (dB) 200 80 100 0 0.09 0 60 –75 –50 –25 0 25 50 75 100 125 –75 –50 –25 0 25 50 75 100 125 150 10 100 1k 10k 100k 1M TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz) LT1463 • TPC07 LT1462 • TPC08 LT1462 • TPC09 5
