Datasheet LTC1150 (Analog Devices) - 2
Описание±15V Zero-Drift Operational Amplifier with Internal Capacitors
Страниц / Страница16 / 2 — ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. …
Формат / Размер файлаPDF / 245 Кб
ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGE. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) (OBSOLETE) PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGE ELECTRICAL CHARACTERISTICS The
42 предложений от 21 поставщиков
IC: операционный усилитель; 2,5МГц; Ch: 1; DIP8; IB: 1нА; Iio: 500пА
LTC1150CN8#PBF
от 1 151 ₽
Зенер
Россия и страны ТС
LTC1150CN8
6 285 ₽
ТаймЧипс
LTC1150CN8#PBF
LTC1150CN8
LTC1150
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Total Supply Voltage (V+ to V–) ... 32V Operating Temperature Range Input Voltage (Note 2) .. (V+ 0.3V) to (V– – 0.3V) LTC1150M
(OBSOLETE)
...–55°C to 125°C Output Short Circuit Duration .. Indefinite LTC1150C .. – 40°C to 85°C Burn-In Voltage ... 32V Storage Temperature Range ... – 65°C to 150°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART ORDER PART I 1 SUPPLY 8 CLOCK OUT NUMBER NUMBER TOP VIEW – IN 2 7 V+ LTC1150CN8 LTC1150CS8 +IN 3 6 OUT I 1 8 CLOCK OUT SUPPLY V – EXT CLOCK 4 – 5 – IN 2 7 V+ IN +IN 3 + 6 OUT N8 PACKAGE EXT CLOCK 8-LEAD PDIP V – 4 5 IN S8 PART TJMAX = 110°C, θJA = 130°C/W S8 PACKAGE MARKING 8-LEAD PLASTIC SO J8 PACKAGE LTC1150MJ8 8-LEAD CERDIP TJMAX = 110°C, θJA = 200°C/W 1150 LTC1150CJ8
OBSOLETE PACKAGE
Consider the N8 or S8 Package as an Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full operating temperature range otherwise specifications are at TA = 25
C. VS =
15V, Pin 1 = Open, unless otherwise noted. LTC1150M LTC1150C PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Input Offset Voltage (Note 3) ±0.5 ±10 ±0.5 ±10 µV Average Input Offset Drift (Note 3) ● ±0.01 ±0.05 ±0.01 ±0.05 µV/°C Long Term Offset Voltage Drift 50 50 nV/√mo Input Offset Current ±20 ±60 ±20 ±200 pA ● ±1.5 ±0.5 nA Input Bias Current ±10 ±50 ±10 ±100 pA ● ±2.5 ±1.0 nA Input Noise Voltage RS = 100Ω, 0.1Hz to 10Hz, TC2 1.8 1.8 µVP-P RS = 100Ω, 0.1Hz to 1Hz, TC2 0.6 0.6 Input Noise Current f = 10Hz (Note 4) 1.8 1.8 fA/√Hz Common Mode Rejection Ratio VCM = V– to 12V ● 110 130 110 130 dB Power Supply Rejection Ratio VS = ±2.375V to ±16V ● 120 145 120 145 dB Large-Signal Voltage Gain RL = 10kΩ, VOUT = ±10V ● 135 180 135 180 dB Maximum Output Voltage Swing RL = 10kΩ ±13.5 ±14.5 ±13.5 ±14.5 V RL = 10kΩ ● 10.5/ 10.5/ –13.5 –13.5 RL = 100kΩ ±14.95 ±14.95 1150fb 2
