Datasheet LT3973, LT3973-3.3, LT3973-5 (Analog Devices) - 2
Описание42V, 750mA Step-Down Regulator with 2.5μA Quiescent Current and Integrated Diodes
Страниц / Страница24 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
Формат / Размер файлаPDF / 479 Кб
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
IC REG BUCK 3.3V 750MA 10DFN. Buck Switching Regulator IC Positive Fixed 3.3V 1 Output 750mA 10-WFDFN Exposed Pad. PMIC -...
LT3973HDD-3.3#TRPBF
196 ₽
Рутоника
LT3973HDD-3.3#TRPBF
344 ₽
LT3973HDD-3.3#TRPBF
371 ₽
LT3973HDD TRPBF
LT3973/LT3973-3.3/LT3973-5
VIN, EN/UVLO Voltage ...42V Operating Junction Temperature Range (Note 2) BOOST Pin Voltage ...55V LT3973E/LT3973E-X .. –40°C to 125°C BOOST Pin Above SW Pin ...25V LT3973I/LT3973I-X .. –40°C to 125°C FB/VOUT, RT, PG Voltage ...6V LT3973H/LT3973H-X ...–40°C to 150°C BD Voltage ..25V Storage Temperature Range .. –65°C to 150°C OUT Voltage ..14V Lead Temperature (Soldering, 10 sec) MSE Only ..300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW *FB/VOUT 1 10 RT *FB/VOUT 1 10 RT OUT 2 9 PG 11 OUT 2 9 PG 11 EN/UVLO 3 GND 8 BD EN/UVLO 3 8 BD GND V VIN 4 7 BOOST IN 4 7 BOOST GND 5 6 SW GND 5 6 SW MSE PACKAGE 10-LEAD PLASTIC MSOP DD PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN θJA = 45°C/W, θJC = 10°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB θJA = 40°C/W, θJC = 5°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB * FB for LT3973, VOUT for LT3973-3.3, LT3973-5.
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3973EDD#PBF LT3973EDD#TRPBF LGCH 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3973IDD#PBF LT3973IDD#TRPBF LGCH 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3973HDD#PBF LT3973HDD#TRPBF LGCH 10-Lead (3mm × 3mm) Plastic DFN –40°C to 150°C LT3973EMSE#PBF LT3973EMSE#TRPBF LTFYS 10-Lead Plastic MSOP –40°C to 125°C LT3973IMSE#PBF LT3973IMSE#TRPBF LTFYS 10-Lead Plastic MSOP –40°C to 125°C LT3973HMSE#PBF LT3973HMSE#TRPBF LTFYS 10-Lead Plastic MSOP –40°C to 150°C LT3973EMSE-3.3#PBF LT3973EMSE-3.3#TRPBF LTGGB 10-Lead Plastic MSOP –40°C to 125°C LT3973IMSE-3.3#PBF LT3973IMSE-3.3#TRPBF LTGGB 10-Lead Plastic MSOP –40°C to 125°C LT3973HMSE-3.3#PBF LT3973HMSE-3.3#TRPBF LTGGB 10-Lead Plastic MSOP –40°C to 150°C LT3973EDD-3.3#PBF LT3973EDD-3.3#TRPBF LGGC 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3973IDD-3.3#PBF LT3973IDD-3.3#TRPBF LGGC 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3973HDD-3.3#PBF LT3973HDD-3.3#TRPBF LGGC 10-Lead (3mm × 3mm) Plastic DFN –40°C to 150°C LT3973EMSE-5#PBF LT3973EMSE-5#TRPBF LTGGD 10-Lead Plastic MSOP –40°C to 125°C LT3973IMSE-5#PBF LT3973IMSE-5#TRPBF LTGGD 10-Lead Plastic MSOP –40°C to 125°C LT3973HMSE-5#PBF LT3973HMSE-5#TRPBF LTGGD 10-Lead Plastic MSOP –40°C to 150°C 3973fb 2 For more information www.linear.com/LT3973 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
