Datasheet LT3641 (Analog Devices) - 3
ОписаниеDual Monolithic Buck Regulator with Power-On Reset and Watchdog Timer
Страниц / Страница28 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 452 Кб
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
14 предложений от 12 поставщиков
IC REG BUCK ADJ DL SYNC 28QFN / Conv DC-DC 4V to 42V Synchronous Step Down Dual-Out 1.265V to 40.97V 1.3A/1.3A...
LT3641EUFD#TRPBF
155 ₽
LT3641EUFD#PBF
348 ₽
LT3641EUFD#PBF
от 405 ₽
LT3641EUFD#TRPBF
LT3641
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 12V, VIN2 = 3.3V, EN/UVLO = 12V, EN2 = 3.3V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Undervoltage Lockout Threshold l 3.6 4 V VIN Undervoltage Release Threshold l 3.8 4.2 V Quiescent Current from VIN EN/UVLO = 0.3V 0.1 1 μA Not Switching 275 375 μA EN/UVLO Threshold Voltage 1.2 1.26 1.3 V EN/UVLO High Bias Current EN/UVLO = Threshold + 60mV 2 μA EN/UVLO Low Bias Current EN/UVLO = Threshold – 60mV 0.1 μA SYNC Input Frequency 0.35 2.5 MHz SYNC Threshold Voltage 0.4 0.8 1 V Switching Frequency RT = 32.4k l 1.75 2 2.35 MHz RT = 182k l 450 500 550 kHz FB1 Voltage l 1.24 1.265 1.29 V FB1 Bias Current FB1 = 1.265V 30 100 nA FB1 Line Regulation 5V < VIN < 30V 0.001 %/V SW1 Minimum Off-Time 70 100 ns SW1 VCESAT ISW1 = 800mA 400 mV SW1 Leakage Current 0.1 1 μA SW1 Current Limit FB1 = 1V (Note 3) l 2.2 2.8 3.4 A FB1 = 0.1V 1.8 A DA Current limit FB1 = 1V (Note 4) l 1.35 1.7 2.2 A FB1 = 0.1V 1 A BST Pin Current ISW1 = 800mA 30 50 mA Minimum BST-SW Voltage 2 2.7 V VIN2 Minimum Operating Voltage l 2.3 2.5 V VIN2 Maximum Operating Voltage l 5.5 V EN2 Threshold Rising l 1.13 1.18 1.23 V EN2 Hysteresis 50 80 110 mV EN2 Bias Current EN2 = EN2 Threshold 50 500 nA FB2 Voltage l 585 600 615 mV FB2 Bias Current FB2 = 0.6V 0 100 nA FB2 Line Regulation 2.5V < VIN2 < 5.5V 0.01 %/V SW2 PMOS Current Limit (Note 5) l 1.5 1.9 2.2 A SW2 NMOS Current Limit (Note 5) l 1.2 1.6 2 A SW2 PMOS RDS(ON) ISW2 = 0.5A (Note 6) 275 mΩ SW2 NMOS RDS(ON) ISW2 = 0.5A (Note 6) 200 mΩ ΔFB2 to Enable PGOOD2 20 40 80 mV ΔFB2 Hysteresis to Disable PGOOD2 20 40 80 mV PGOOD2 Voltage FB2 = 0.6V, IPGOOD2 = 1mA 200 320 mV 3641fa 3
