Datasheet LTC3631 (Analog Devices) - 9
ОписаниеHigh Efficiency, High Voltage 100mA Synchronous Step-Down Converter
Страниц / Страница22 / 9 — operaTion (Refer to Block Diagram). Input Undervoltage and Overvoltage …
Формат / Размер файлаPDF / 538 Кб
operaTion (Refer to Block Diagram). Input Undervoltage and Overvoltage Lockout. Peak Inductor Current Programming
operaTion (Refer to Block Diagram) Input Undervoltage and Overvoltage Lockout Peak Inductor Current Programming
43 предложений от 20 поставщиков
IC REG BUCK INV 5V 0.1A 8MSOP / Conv DC-DC 4.5V to 45V Synchronous Step Down Single-Out 5V 0.1A Automotive 8-Pin...
LTC3631EMS8E-5#PBF
от 846 ₽
727GS
LTC3631EMS8E-5#PBF
от 2 333 ₽
LTC3631EMS8E-5#PBF
ЗУМ-СМД
LTC3631EMS8E-5#TRPBF
LTC3631
then the output voltage will be limited by the ramp rate from the ISET pin to ground. The 1µA current sourced out on the SS pin instead. The internal and external soft-start of this pin through the resistor generates a voltage that is functions are reset on start-up and after an undervoltage translated into an offset in the peak current comparator, or overvoltage event on the input supply. which limits the peak inductor current. In order to ensure a smooth start-up transition in any
application, the internal soft-start also ramps the peak inductor current from 50mA during its 1ms ramp time to The LTC3631 implements a protection feature which dis- the set peak current threshold. The external ramp on the ables switching when the input voltage is not within the SS pin does not limit the peak inductor current during 4.5V to 45V operating range. If VIN falls below 4V typical start-up; however, placing a capacitor from the ISET pin (4.35V maximum), an undervoltage detector disables to ground does provide this capability. switching. Similarly, if VIN rises above 50V typical (47V minimum), an overvoltage detector disables switching.
When switching is disabled, the LTC3631 can safely sustain The offset of the peak current comparator nominally input voltages up to the absolute maximum rating of 60V. provides a peak inductor current of 225mA. This peak Switching is enabled when the input voltage returns to the inductor current can be adjusted by placing a resistor 4.5V to 45V operating range. 3631fe For more information www.linear.com/LTC3631 9 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Application Related Parts
