Datasheet ADA4945-1 (Analog Devices) - 6
ОписаниеHigh-Speed, ±0.3µV/°C Offset Drift, Fully Differential ADC Driver
Страниц / Страница18 / 6 — ADA4945-1. Preliminary Technical Data. Full Power Mode. Low Power Mode. …
ВерсияPrC
Формат / Размер файлаPDF / 468 Кб
ADA4945-1. Preliminary Technical Data. Full Power Mode. Low Power Mode. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADA4945-1 Preliminary Technical Data Full Power Mode Low Power Mode Parameter Test Conditions/Comments Min Typ Max Unit
25 предложений от 9 поставщиков
IC ADC DRIVER 16LFCSP. ADC Driver IC Data Acquisition 16-LFCSP (3x3). Linear - Amplifiers - Special Purpose
ADA4945-1ACPZ-RL
174 ₽
ADA4945-1ACPZ-RL
487 ₽
ADA4945-1ACPZ-RL
от 696 ₽
ADA4945-1ACPZ-RL
3 492 ₽
ADA4945-1 Preliminary Technical Data Full Power Mode Low Power Mode Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
DGND PIN VOLTAGE RANGE −VS +VS – –VS +VS – V 2.5 2.5 POWER SUPPLY Operating Range 3 10 3 10 V Quiescent Current per Full power mode, MODE = 10 V 4 TBD TBD mA Amplifier, Enabled Low power mode, MODE = 0 V TBD 1.4 TBD mA Disabled Full power mode, MODE = 10 V 50 TBD TBD µA Low power mode, MODE = 0 V TBD 50 TBD µA +PSRR ΔVOS, dm/ΔVS, ΔVS = 1 V p-p −120 −120 dB −PSRR ΔVOS, dm/ΔVS, ΔVS = 1 V p-p −120 −120 dB OPERATING TEMPERATURE RANGE −40 +125 −40 +125 °C Rev. PrA | Page 6 of 18 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Specifications Supply Voltage (VS) = 10 V Positive Input (+DIN) or Negative Input (–DIN) to Differential Output Voltage (VOUT, dm) Performance VOCM to VOUT, cm Performance General Performance VS = 5 V +DIN or –DIN to VOUT, dm Performance VOCM to VOUT, cm Performance General Performance VS = 3 V +DIN or –DIN to VOUT, dm Performance VOCM to VOUT, cm Performance General Performance Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Terminology Outline Dimensions
