Datasheet LTC6432-15 (Analog Devices) - 4
Описание100kHz to 1.4GHz Differential ADC Driver/IF Amplifier
Страниц / Страница20 / 4 — AC ELECTRICAL CHARACTERISTICS. The. denotes the specifications which …
Формат / Размер файлаPDF / 1.6 Мб
AC ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the full operating
AC ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full operating
IC ADC DRIVER 24QFN. ADC Driver IC Audio 24-QFN (4x4). Linear - Amplifiers - Special Purpose
LTC6432BIUF-15#TRPBF
178 ₽
455 ₽
524 ₽
LTC6432-15
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TCASE = 30°C (Note 3). VCC = 5V, ZSOURCE = ZLOAD = 100Ω, unless otherwise noted, measurements are performed using Test Circuit A, measuring from 50Ω SMA to 50Ω SMA without de-embedding (Note 4). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Frequency = 50MHz
S21 Differential Power Gain De-Embedded to Package w Ext. 1µF FDBK Capacitor 15.9 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, ∆f = 1MHz, ZO = 100Ω Grade A 48.0 dBm Grade B 45 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, ∆f = 1MHz, ZO = 100Ω Grade A –92 dBc Grade B –86 dBc HD2 Second Harmonic Distortion POUT = 8dBm –85.5 dBc HD3 Third Harmonic Distortion POUT = 8dBm –90.5 dBc P1dB Output 1dB Compression Point 22.9 dBm NF Noise Figure De-Embedded to Package for Balun Input Loss 2.9 dB
Frequency = 150MHz
S21 Differential Power Gain De-Embedded to Package w Ext. 1µF FDBK Capacitor 14.5 15.9 16.5 dB l 14.2 16.8 OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, ∆f = 8MHz, ZO = 100Ω Grade A 47.0 50.3 dBm Grade B 47 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, ∆f = 8MHz, ZO = 100Ω Grade A –96.6 dBc Grade B –90 dBc HD2 Second Harmonic Distortion POUT = 8dBm –92.2 dBc HD3 Third Harmonic Distortion POUT = 8dBm –86.5 dBc P1dB Output 1dB Compression Point 22.7 dBm NF Noise Figure De-Embedded to Package for Balun Input Loss 3.2 dB
Frequency = 240MHz
S21 Differential Power Gain De-Embedded to Package w Ext. 1µF FDBK Capacitor 15.8 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, ∆f = 1MHz, ZO = 100Ω Grade A 45 dBm Grade B 42 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, ∆f = 1MHz, ZO = 100Ω Grade A –86 dBc Grade B –80 dBc HD2 Second Harmonic Distortion POUT = 8dBm –93.7 dBc HD3 Third Harmonic Distortion POUT = 8dBm –81.5 dBc P1dB Output 1dB Compression Point 22.6 dBm NF Noise Figure De-Embedded to Package for Balun Input Loss 3.4 dB
Frequency = 300MHz
S21 Differential Power Gain De-Embedded to Package w Ext. 1µF FDBK Capacitor 15.8 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, ∆f = 1MHz, ZO = 100Ω Grade A 43.5 dBm Grade B 40 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, ∆f = 1MHz, ZO = 100Ω Grade A –83 dBc Grade B –76 dBc HD2 Second Harmonic Distortion POUT = 8dBm –90.7 dBc HD3 Third Harmonic Distortion POUT = 8dBm –81.4 dBc P1dB Output 1dB Compression Point 22.5 dBm NF Noise Figure De-Embedded to Package for Balun Input Loss 3.6 dB 643215f 4 For more information www.linear.com/LTC6432-15 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information Differential S Parameters Package Description Typical Application Related Parts
