Datasheet LTC6412 (Analog Devices) - 3
Описание800MHz, 31dB Range Analog-Controlled VGA
Страниц / Страница24 / 3 — DC ELECTRICAL CHARACTERISTICS. The. denotes specifi cations that apply …
Формат / Размер файлаPDF / 505 Кб
DC ELECTRICAL CHARACTERISTICS. The. denotes specifi cations that apply over the full operating
DC ELECTRICAL CHARACTERISTICS The denotes specifi cations that apply over the full operating
IC OPAMP VGA 1 CIRCUIT 24QFN. Variable Gain Amplifier 1 Circuit Differential 24-QFN (4x4). Linear - Amplifiers - Instrumentation, OP Amps,...
LTC6412CUF#TRPBF
371 ₽
Рутоника
LTC6412CUF#TRPBF
474 ₽
LTC6412CUF#TRPBF
547 ₽
LTC6412CUF#TRPBF
LTC6412
l
denotes specifi cations that apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. DC electrical performance measured using DC test circuit schematic. VIN(DIFF) is defi ned as (+IN) – (–IN). VOUT(DIFF) is defi ned as (+OUT) – (–OUT). VIN(CM) is defi ned as [(+IN) + (–IN)]/2. VOUT(CM) is defi ned as [(+OUT) + (–OUT)]/2. Unless noted otherwise, default operating conditions are VCC = 3.3V, EN = 0.8V, SHDN = 2.2V, +VG tied to VREF (negative gain slope mode), VOUT(CM) = 3.3V. Differential power gain defi ned at ZSOURCE = 50Ω differential and ZLOAD = 200Ω differential. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Gain Characteristics
GMAX Maximum Differential Power Gain (Note 4) –VG = 0V, VIN(DIFF) = 100mV 16.1 17.1 18.1 dB l 15.5 18.7 dB GMIN Minimum Differential Power Gain (Note 4) –VG = 1.2V, VIN(DIFF) = 200mV –16.2 –14.9 –13.6 dB l –16.8 –13.0 dB GRANGE Differential Power Gain Range GMAX-GMIN 30.7 31.9 33.1 dB l 30.1 33.7 dB TCGAIN Temperature Coeffi cient of Gain at Fixed VG –VG = 0V to 1.2V –0.007 dB/°C GSLOPE Gain Control Slope –VG = 0.2V to 1.0V, 85 Points, Slope of the –34.1 –32.9 –31.7 dB/V Least-Square Fit Line l –34.7 –31.1 dB/V GCONF(AVE) Average Conformance Error to Gain Slope Line –VG = 0.2V to 1.0V, 85 Points, Standard 0.12 0.20 dB Error to the Least-Square Fit Line GCONF(MAX) Maximum Conformance Error to Gain Slope –VG = 0.2V to 1.0V, 85 points, Maximum 0.20 0.45 dB Line Error to the Least-Square Fit Line
+IN and –IN Pins
RIN(GMAX) Differential Input Resistance at Maximum Gain –VG = 0V, VIN(DIFF) = 100mV 49 57 65 Ω l 47 67 Ω RIN(GMIN) Differential Input Resistance at Minimum Gain –VG = 1.2V, VIN(DIFF) = 200mV 49 57 65 Ω l 47 67 Ω VINCM(GMAX) Input Common Mode Voltage at Maximum Gain –VG = 0V, DC Blocking Capacitor to Input 640 mV VINCM(GMIN) Input Common Mode Voltage at Minimum Gain –VG = 1.2V, DC Blocking Capacitor to Input 640 mV
+VG, –VG, and VREF Pins
RIH(+VG) +VG Input High Resistance +VG = 1.0V, –VG Tied to VREF , 7.8 9.2 10.6 kΩ RIN(+VG) = 1V/Δ IIL(+VG) l 7.2 11.6 kΩ RIH(–VG) –VG Input High Resistance –VG = 1.0V, +VG Tied to VREF , 7.8 9.2 10.6 kΩ RIN(–VG) = 1V/Δ IIL(–VG) l 7.2 11.6 kΩ IIL(+VG) +VG Input Low Current +VG = 0V, –VG Tied to VREF –9 –5 –1 μA l –10 –1 μA IIL(–VG) –VG Input Low Current –VG = 0V, +VG Tied to VREF –9 –5 –1 μA l –10 –1 μA VREF Internal Bias Voltage –VG = 0V, +VG Tied to VREF 590 615 640 mV l 580 650 mV 6412fa 3
