Datasheet LTC6412 (Analog Devices) - 7
Описание800MHz, 31dB Range Analog-Controlled VGA
Страниц / Страница24 / 7 — AC ELECTRICAL CHARACTERISTICS. The. denotes specifi cations that apply …
Формат / Размер файлаPDF / 505 Кб
AC ELECTRICAL CHARACTERISTICS. The. denotes specifi cations that apply over the full operating
AC ELECTRICAL CHARACTERISTICS The denotes specifi cations that apply over the full operating
29 предложений от 17 поставщиков
LTC6412CUF#TRPBF
191 ₽
Эиком
LTC6412CUF#PBF
от 1 746 ₽
LTC6412CUF#TRPBF
ЗУМ-СМД
LTC6412CUF#PBF
LTC6412
l
denotes specifi cations that apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Typical AC electrical performance measured in demo board DC1464A (Figure 3, Test Circuit A) unless otherwise noted. Default operating conditions are VCC = 3.3V, EN = 0.8V, SHDN = 2.2V, +VG tied to VREF (negative gain slope mode), and ZSOURCE = ZLOAD = 50Ω unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS 380MHz Signal
GMAX Maximum Gain –VG = 0V, Test Circuit B 17 dB GMIN Minimum Gain –VG = 1.2V, Test Circuit B –14 dB GRANGE Gain Range GMAX-GMIN 31 dB IM3 Third-Order Intermodulation f1 = 379.5MHz, f2 = 380.5MHz, –72 dBc POUT = –6dBm/Tone, –VG = 0V to 1.0V OIP3 Output Third-Order Intercept f1 = 379.5MHz, f2 = 380.5MHz, 30 dBm POUT = –6dBm/Tone, –VG = 0V to 1.0V P1dBGMAX Output 1dB Compression Point at Max Gain –VG = 0V (Note 6) 11 dBm NFGMAX Noise Figure at Maximum Gain –VG = 0V (Note 5) 10.5 dB NFGMIN Noise Figure at Minimum Gain –VG = 1.2V (Note 5) 42 dB
Note 1:
Note 5:
en can be calculated from 50Ω NF with the formula: may cause permanent damage to the device. Exposure to any Absolute en = √{4kT(50)(10NF/10 – 1)} Maximum Rating condition for extended periods may affect device where reliability and lifetime. RF input power rating is guaranteed by design and e engineering characterization, but not production tested. The absolute n = Input referred voltage noise in V/√Hz maximum continuous RF input power shall not exceed +15dBm NF = 50Ω noise fi gure in dB
Note 2:
The LTC6412C/LTC6412I are guaranteed functional over the k = Boltzmann’s constant = 1.38 • 10–23J/°K operating temperature range of –40°C to 85°C. T = Absolute temperature in °K = °C + 273
Note 3:
The LTC6412C is guaranteed to meet specifi ed performance from
Note 6:
P1dB compression of the output amplifi er cannot be achieved 0°C to 70°C. It is designed, characterized and expected to meet specifi ed in the minimum gain state while complying with the absolute maximum performance from –40°C and 85°C but is not tested or QA sampled rating for input RF power. at these temperatures. The LT6412I is guaranteed to meet specifi ed performance from –40°C to 85°C.
Note 4:
Power gain is defi ned at ZSOURCE = 50Ω and ZLOAD = 200Ω. Voltage gain for this test condition is 6dB higher than the stated power gain. 6412fa 7
