Datasheet LTC6416 (Analog Devices) - 3
Описание2GHz Low Noise Differential 16-Bit ADC Buffer
Страниц / Страница20 / 3 — 3.6V ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which …
Формат / Размер файлаPDF / 401 Кб
3.6V ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full
3.6V ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full
14 предложений от 14 поставщиков
IC BUFFER 1 CIRCUIT 10DFN. Buffer Amplifier 1 Circuit Differential 10-DFN (3x2). Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
LTC6416CDDB-TRMPBF
LTC6416CDDB#TRPBF
LTC6416CDDB#PBF
ТаймЧипс
LTC6416CDDB-TRPBF
LTC6416
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3.6V, GND = 0V, No RLOAD, CLOAD = 6pF. VCM = 1.25V, CLHI = V+, CLLO = 0V unless otherwise noted. VINCM is defi ned as (IN+ + IN–)/2. VOUTCM is defi ned as (OUT+ + OUT–)/2. VINDIFF is defi ned as (IN+ – IN–). VOUTDIFF is defi ned as (OUT+ – OUT–). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IVRMIN Input Voltage Range, IN+, IN– Defi ned by Output Voltage Swing Test l 0.1 V (Minimum) (Single-Ended) IVRMAX Input Voltage Range IN+, IN– Defi ned by Output Voltage Swing Test l 2.4 V (Maximum) (Single-Ended) IB Input Bias Current, IN+, IN– IN+ = IN– = 1.25V l –15 –5 15 μA RINDIFF Differential Input Resistance VINDIFF = ±1.2V l 9 12 15 kΩ CINDIFF Differential Input Capacitance 1 pF RINCM Input Common Mode Resistance IN+ = IN– = 0.65V to 1.85V 6 kΩ CMRR Common Mode Rejection Ratio IN+ = IN– = 0.65V to 1.85V, 63.5 83 dB CMRR = (VOUTDIFF/GDIFF/1.2V) l 59.6 dB eN Input Noise Voltage Density f = 100kHz 1.8 nV/√Hz iN Input Noise Current Density f = 100kHz 6.5 pA/√Hz
Output Common Mode Voltage Control
GCM VCM Pin Common Mode Gain VCM = 0.65V to 1.85V l 0.9 0.96 1.05 V/V VINCMDEFAULT Default Input Common Mode Voltage VINCM. IN+, IN–, VCM Pin Floating l 1.3 1.38 1.45 V VOS (VCM – VINCM) Offset Voltage, VCM to VINCM VCM – VINCM, VCM = 1.25V l –70 –28 70 mV VOUTCMDEFAULT Default Output Common Mode Voltage Inputs Floating, VCM Pin Floating l 1.25 1.34 1.45 V VOS (VCM – VOUTCM) Offset Voltage, VCM to VOUTCM VCM – VOUTCM, VCM = 1.25V l –60 15 60 mV VOUTCMMIN Output Common Mode Voltage Range VCM = 0.1V 0.37 0.5 V (Minimum) l 0.55 V VOUTCMMAX Output Common Mode Voltage Range VCM = 2.7V 2.3 2.46 V (Maximum) l 2.25 V VCMDEFAULT VCM Pin Default Voltage l 1.325 1.36 1.425 V RVCM VCM Pin Input Resistance l 2.5 3.8 5.1 kΩ CVCM VCM Pin Input Capacitance 1 pF IBVCM VCM Pin Bias Current VCM = 1.25V l –50 –32 50 μA
DC Clamping Characteristics
VCLHIDEFAULT Default Output Clamp Voltage, High l 2.3 2.45 2.6 V VOS (CLHI – VOUTCM) Offset Voltage, CLHI to VOUTCM l –55 13 55 mV VCLLODEFAULT Default Output Clamp Voltage, Low l 0.125 0.265 0.425 V VOS (CLLO – VOUTCM) Offset Voltage, CLLO to VOUTCM l –120 –70 0 mV RCLHI CLHI Pin Input Resistance VCLHI = 2.45V l 3 4.1 5 kΩ IBCLHI CLHI Pin Bias Current VCLHI = 2.45V l –25 –1 25 μA RCLLO CLLO Pin Input Resistance VCLLO = 0.275V l 1.5 2.3 3.2 kΩ IBCLLO CLLO Pin Bias Current VCLLO = 0.275V l –25 4.5 25 μA
Power Supply
VS Supply Voltage Range l 2.7 3.9 V IS Supply Current 33 42 51 mA l 54 mA PSRR Power Supply Rejection Ratio VS = 2.7V to 3.6V l 57.5 80 dB 6416f 3
