Datasheet LTC6400-20 (Analog Devices) - 10
Описание1.8GHz Low Noise, Low Distortion Differential ADC Driver for 300MHz IF
Страниц / Страница16 / 10 — PIN FUNCTIONS. V+ (Pins 1, 3, 10):. –OUTF, +OUTF (Pins 6, 7):. E (Pin …
Формат / Размер файлаPDF / 231 Кб
PIN FUNCTIONS. V+ (Pins 1, 3, 10):. –OUTF, +OUTF (Pins 6, 7):. E (Pin 11):. VOCM (Pin 2):. +IN (Pins 13, 14):
PIN FUNCTIONS V+ (Pins 1, 3, 10): –OUTF, +OUTF (Pins 6, 7): E (Pin 11): VOCM (Pin 2): +IN (Pins 13, 14):
32 предложений от 16 поставщиков
Микросхема Буферный усилитель, LINEAR TECHNOLOGY LTC6400IUD-20#TRPBF Differential Amplifier, Low Noise, 1 Amplifiers, 2mV, 20dB, 1.84GHz, -40℃, 85℃
LTC6400IUD-20#PBF
от 1 058 ₽
Зенер
Россия и страны ТС
LTC6400IUD-20#PBF
от 1 068 ₽
LTC6400IUD-20
LTC6400IUD-20 TRPBF
LTC6400-20
Positive Power Supply (Normally tied
Filtered Outputs. These pins to 3V or 3.3V). All three pins must be tied to the same have 50Ω series resistors and a 2.7pF shunt capacitor. voltage. Bypass each pin with 1000pF and 0.1μF capaci- ⎯
E
N
A
B
L
E (Pin 11):
This pin is a logic input referenced to tors as close to the pins as possible. VEE. If low, the part is enabled. If high, the part is disabled
VOCM (Pin 2):
This pin sets the output common mode and draws approximately 1mA supply current. voltage. A 0.1μF external bypass capacitor is recom-
+IN (Pins 13, 14):
Positive Input. Pins 13 and 14 are mended. internally shorted together.
V– (Pins 4, 9, 12, 17):
Negative Power Supply (GND). All
–IN (Pins 15, 16):
Negative Input. Pins 15 and 16 are four pins must be connected to same voltage/ground. internally shorted together.
–OUT, +OUT (Pins 5, 8):
Unfi ltered Outputs. These pins
Exposed Pad (Pin 17):
V–. The Exposed Pad must be have series resistors, ROUT 12.5Ω. connected to same voltage/ground as pins 4, 9, 12.
BLOCK DIAGRAM
V– ENABLE V+ V– 12 11 10 9 BIAS CONTROL RG RF ROUT +IN +OUT 100Ω 1000Ω 12.5Ω 13 8 RFILT +OUTF 50Ω +IN IN+ OUT– 7 14 C R FILT FILT –IN 1.7pF –OUTF 50Ω 15 6 IN– OUT+ RG RF ROUT –IN –OUT 100Ω 1000Ω 12.5Ω 16 5 2k COMMON MODE CONTROL 5.3pF 640020 BD 1 2 3 4 V+ VOCM V+ V– 640020f 10
